cylinder #2 & #3 misfire
Old Jul 18, 2005 | 11:48 PM
rebbaz's Avatar
Car Info: civic
so does anyone know what i should change before i take it in. i was hoping i could change as many things so that i save on labor prior to having a mechanic look at it. i am at 46,XXX and i changed the spark plugs, tranny fluid, rear diff fluid, oil, brake fluid(just wanted to tell all i have done). i was thinking about draining the coolent, but i have also heard that since the 2nd and 3rd cylinder do that during the summer cause they're next to the turbo and heat up. any ideas? i was thinking about getting a new fuel filter...maybe....
dunno.
Old Jul 18, 2005 | 11:55 PM
soggynoodles's Avatar
try changing the spark plug wires.
Were the new plug gapped to spec?
Old Jul 19, 2005 | 08:54 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
you don't have any mods do you?
Old Jul 19, 2005 | 08:55 PM
rebbaz's Avatar
Car Info: civic
yeah, the plugs were gapped, even the old plugs looked fine, they were kinda white!
thankx for the input.
Old Jul 19, 2005 | 08:57 PM
rebbaz's Avatar
Car Info: civic
well, i put on an HKS bov but this was after the misfire. but even without it, it still misfires. other than that, she's stock.
Old Jul 19, 2005 | 09:23 PM
you should swap out the fuel filter at around 30k. maybe that will help.
and try to clean all the connections that lead to the spark.
Old Jul 20, 2005 | 11:08 AM
rebbaz's Avatar
Car Info: civic
awesome, i was thinking about doing the fuel filter, its just right there in the front. thankx for the input.
anything else?
Old Jul 22, 2005 | 03:32 PM
ej20boost's Avatar
Car Info: My 2009 FIT for sale!!!!!!!!!!
is the car still misfiring?? is fuel pressure good?? is the injectors firing... check power and ground?? is fuel quality good....... i heard of misfires from "bad" gas. it may be dirty injectors. has the car been sitting for along time?? maybe coils.... could be a problem in wiring harness or ECU in the worst case scenerio(lets hope not). check the wiring harness(maybe next to the turbo) from the coils if its chafing or something..... here is my 2 cents. hope this helps and good luck!
dunno.
Old Jul 22, 2005 | 04:23 PM
myroncuz's Avatar
hmm, i currently have a cel that indicates misfire in cylinder 4.. i thinks my problem is due to having a rip in my turbo inlet hose... therefore casing me to run rich and have carbon build up on my spark plug... maybe re check your plugs..
Old Jul 22, 2005 | 04:33 PM
rebbaz's Avatar
Car Info: civic
awesome, thankx for the idea's. the car was sitting around for a while(i bought it with a salvaged title, but had commuted and put about 9,000 miles on it in the last 7 months). for some reason, the CEL just disappeard the other day, but i plan on checking if my spark plug wires are still good. i will look into a new feul filter and plan on using some of that STP fuel injector cleaner, but will that work all that well?
thankx again to everyone.
Old Jul 22, 2005 | 04:35 PM
myroncuz's Avatar
doesnt hurt to try.. funny thing is when i use injector cleaners, my car runs and idles funny. let me know
Old Jul 23, 2005 | 10:33 AM
rebbaz's Avatar
Car Info: civic
weird. very very odd. but i think ill use it just to be safe... i think.... and i'll post up how it works out.
kcismo
Jun 23, 2005 11:28 AM
mbquarts
Apr 19, 2005 12:01 PM
jaypowell78
Apr 8, 2005 06:45 AM
Madball
25
Mar 29, 2004 08:29 PM
my02_impreza
May 29, 2003 11:48 PM
