cobb tuning shim under valves
Old Apr 19, 2003 | 06:28 PM
DeliciouSpeed's Avatar
I don't belive that mod is worth that much money. A whole Jun valve train can be had for less than that. I'd hit them up, get their cams too and rip-an 8-8500rpm redline would be lovely providing you have the mods to make such a trip worth while. What are your goals with the car? Are you doing cams right now?
k2
Old Apr 19, 2003 | 06:36 PM
hotrod's Avatar
don't raise red line without something
I have not used them but have heard from several sources that it can be very expensive to run higher rpms with out undershim system.
The stock configuration can spit a shim if you valve float it. When it tosses the shim out, it usually wrecks lots of expensive stuff when the loose shim gets wedged some place it does not belong.
Just make sure the vendor certifies the new valve train will not have that problem at the rpm you want to run.
larry
Old Apr 22, 2003 | 06:56 AM
I'm gonna get back to you, let me find some info.
Old Apr 23, 2003 | 12:48 PM
SJwrx's Avatar
Car Info: STi Motor Mounts, Synthetic Fluids, nothing else yet
http://www.wrxforum.com/cgi-bin/ultimatebb.cgi
Ask them directly.
Rich
Old Apr 25, 2003 | 04:36 PM
http://www.junauto.co.jp/processing/ej20/
Jun lists these parts as necessary for use w/ their cams:
Change processing into inner shim type
Tappet shim clearance adjusting
Head parts set up
SUBARU STOCK PARTS
But the part numbers are not listed anywhere I could find them on the web. Call your prefered Jun vendor. That Cobb kit is way over priced for what it is IMO. They sell Ferrera valves for 1g for Gods sake. 16 Valves man!
Old Apr 26, 2003 | 05:06 PM
There are vendors here that can hook you up man. Worse case, try Alex(I might try him first even), If there's a buck to be made best believe he'll take up the cause. I mean that in the highest respect, from hustler to hustler .
k2
xhengmanx
Feb 1, 2019 03:46 PM
nation
Jan 13, 2012 09:39 AM
Teddy
Aug 19, 2009 06:55 AM
kenshin01
Jul 8, 2006 07:16 PM
lewsthomas
May 11, 2006 12:55 PM
