STi Brake Shim order
Old Apr 14, 2006 | 03:40 PM
lewsthomas's Avatar
Car Info: 2001 2.5 rs
Hello Folks,
Did a search and can not find a answer to the following.
On the 04 STi front brakes there are 2 shims on each caliper.
When installing new pads are these two shims supposed to be used.
I was not paying attention to these and once I took the calipers and pins off these fell out with the pads.
The angle cut shims have a arrow cut in them should this face toward the front of the car.
Are the shims placed on the inside pads or the outside pads.
Thanks for the help,
Learnt to pay closer attention next time.
Lew
Old May 10, 2006 | 08:27 PM
qingshan's Avatar
Car Info: '06 CGM Fo/12 SWP Sti
I have almost the same problem.
The shims go on the back of the pad and are contacted by the pistons. But on my 05 there are 4 not 2/caliper
what is the order and ther orientaion - there are arrows on 2 - whre do they point?
Old May 11, 2006 | 12:55 PM
qingshan's Avatar
I have just been told that if you have the shims with the arrows cut in them that the arrows should point up
isaac3388
Hawaii Classifieds
Apr 6, 2013 06:05 PM
nation
Jan 13, 2012 09:39 AM
Teddy
Aug 19, 2009 06:55 AM
kenshin01
Jul 8, 2006 07:16 PM
natedizzel
Apr 26, 2003 05:06 PM
