Check engine light came on????
Old Aug 30, 2003 | 09:27 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Yes. A catless exhaust removes the cat in the downpipe which is the primary catalyst and the one which the ECU monitors with the rear 02 sensor. The CEL may not come on right away, it depends on the type of driving you do since the ECU performs its catalyst efficiency tests during highway speed, steady throttle conditions. If you have a CEL now after installing a catless system it is most likely a P0420 catalyst inefficiency code although you should get it scanned to be sure it isn't something else.
You can get one of the MIL eliminators or fixes to "fool" the ECU and prevent the CEL.
aaron222
Apr 12, 2005 11:18 AM
1neWRX
Jul 6, 2004 11:39 PM
Meeocky
Jul 2, 2004 11:42 AM
kayo
13
Dec 24, 2003 07:27 AM
spankmeplz700
Jan 4, 2003 11:28 AM
