"check Engine" light blinking??
Old Aug 8, 2003 | 03:55 PM
Mulder's Avatar
Car Info: 02 WRX WRB
On a stock system (no unichip, UTEC etc) a flashing CEL indicates a real-time misfire. There is no indication for knock.
You may want to check your coil packs and plugs to make sure the wiring is secure and the plugs are in good shape.
If you have mods the problem may be related to that.
Old Aug 9, 2003 | 08:59 PM
jigga's Avatar
Car Info: 02 wrx
ahh... the blinking CEL.... means that there is something very wrong with your car. You definitely should check the ecu with a scanner to see if any codes are stored, and as mentioned above, check the coil packs.... Next, check your spark plugs....
The flashing CEL occurred to ne a few weeks ago... The cure? Buying a brand new shortblock for my car since pistons 2 and 4 were shot......
Filthiest
May 14, 2015 05:18 PM
hey1230000
Sep 29, 2008 10:59 AM
chinoyboi
Sep 29, 2008 12:23 AM
waynewrx
Apr 18, 2005 08:50 PM
rash
May 17, 2003 12:32 PM
