CEL trouble code P0122 (was: need help)
Old Apr 2, 2007 | 11:39 PM
kevin_ej20's Avatar
Car Info: 02 wrx
Exclamation CEL trouble code P0122 (was: need help)
my check light came on p0122 its something to do with the maf. have any ideas thanks
Old Apr 3, 2007 | 07:22 PM
MO REX's Avatar
Car Info: 02 PSM WRX
P0122 is a code for Throttle Position Sensor Circuit low input. If you want to troubleshoot this you will need a multimeter. Do you have one? Is your car idling rough, stalling or driving funny?
Old Apr 4, 2007 | 02:01 PM
kevin_ej20's Avatar
Car Info: 02 wrx
yea when i let go of the gas the rpm drops below 500 rpm and jumps back up the normal
Old Apr 4, 2007 | 02:03 PM
kevin_ej20's Avatar
Car Info: 02 wrx
i cleaned the MAF but still the same
Old Apr 4, 2007 | 03:59 PM
MO REX's Avatar
The MAF isn't the problem if the code is P0122. P0122 is a code for Throttle Position Sensor Circuit low input and AFAIK the best way to troubleshoot this problem is with a multimeter. Do you have one?
Old Apr 8, 2007 | 12:48 PM
kevin_ej20's Avatar
Car Info: 02 wrx
i replaced the Throttle Position Sensor but still actin funny
Old Apr 8, 2007 | 04:40 PM
MO REX's Avatar
You can't just go replacing parts without troubleshooting first. That's why I've asked you if you have a multimeter two times.
It could be something simple and the only way to figure it out is by taking readings with a multimeter.
Old Apr 8, 2007 | 06:03 PM
kevin_ej20's Avatar
Car Info: 02 wrx
yea i have one
Old Apr 8, 2007 | 08:27 PM
MO REX's Avatar
I've been very busy the last week but I'll try to post the way to troubleshoot this problem tomorrow. I have the manual on my hard drive but I'm not exactly sure what I need to do to make a non PDF file that I can post. I know I can print a copy and scan it but I'm out of black ink right now.
I'll do my best to get it to you ASAP.
Old Apr 11, 2007 | 06:34 PM
MO REX's Avatar
Sorry it took so long.
Good luck
Attached Thumbnails CEL trouble code P0122 (was: need help)-tps1.jpg   CEL trouble code P0122 (was: need help)-tps2.jpg   CEL trouble code P0122 (was: need help)-tps3.jpg
mistaanime
Jan 23, 2014 09:23 AM
brucelee
Aug 16, 2009 02:41 PM
subaruferrucci
Apr 11, 2006 12:51 PM
tommysyko
Mar 16, 2006 01:47 AM
Wrxplaya11
Mar 13, 2006 11:39 AM
