Help.CEL light, trouble code PO546?Suggestions?
Old Nov 15, 2003 | 06:08 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Answered you on NASIOC.
Old Mar 13, 2006 | 09:57 AM
stevedood's Avatar
Car Info: _
Can you guys find the link to the Nasioc thread?
Old Mar 13, 2006 | 10:23 AM
Mulder's Avatar
Who the hell knows where it is, it's almost three years old. But if you are asking about this same code, I can tell you it's caused by a failed EGT probe in the uppipe. If the probe is still in place in either the stock uppipe or an aftermarket one it has probably failed electrically and is an open circuit internally. It's very common for them to go bad after a short time in a catless uppipe.
This code can also be caused by a problem with the wiring to the probe.
Old Mar 13, 2006 | 10:35 AM
stevedood's Avatar
Car Info: _
Yeah...it's happened the past 2 weekends, driving uphill under moderate loading, and I was guessing it was the EGT probe in my Helix Uppipe, although a friend thought it might be starved a little from clogged injectors = high EGT?
It's been about 2 years since I installed the uppipe and not a single CEL until recently. I guess I'll replace the EGT probe...unless it's waste of time and I should just put in the 2.2 kOhm resistors?
Old Mar 13, 2006 | 11:39 AM
Mulder's Avatar
If your uppipe is catless, the probe no longer serves a useful purpose and you should do the resistor mod, and replace the probe itself with a bolt.
For useful EGT readings you need to get an EGT gauge with its own probe mounted in the manifold.
brucelee
Aug 16, 2009 02:41 PM
blkdout04
Sep 15, 2008 07:09 AM
kevin_ej20
Apr 11, 2007 06:34 PM
subaruferrucci
Apr 11, 2006 12:51 PM
tommysyko
Mar 16, 2006 01:47 AM
