CEL problems, any idea's?
Old Oct 7, 2003 | 08:09 PM
Mulder's Avatar
Car Info: 02 WRX WRB
What year is your car? If it is an '04 the standard CEL fixes for the '03's and earlier don't work.
Old Oct 7, 2003 | 09:35 PM
downshift's Avatar
Car Info: dream car Subaru STi
yea. u need to get a reflashed ecu such as from vishnu or cobb turning or some thing. basically ur cel wont go away until u get another ecu programmed to have u boost more with more hp, thats wat i think will solve it, i doubt there is a way to get rid of the cel just by using 03 piping.
Old Oct 8, 2003 | 04:05 AM
Mulder's Avatar
You can check Scoobysport, I believe they have a fix for the 04s.
Old Oct 8, 2003 | 12:29 PM
mmboost's Avatar
I've always guessed that they way you figure out approriate voltage to a sensor is to put a meter inline with the sensor and record voltage levels under various conditions. Isn't this how "they" figured out to shove a 2.2k resistor in the EGT sensor socket for catless uppipes in v7 WRXs?
Well why doesn't someone with a stock v8 do that and tell us what the voltage should be. Do a little V=IR and put the right resistor in.
It should be that simple, right?
jason
Old Oct 23, 2003 | 08:51 AM
WRXncrew's Avatar
Car Info: http://goo.gl/XpkO0b & '99 SF 'S'
Try the mechanical CEL fix for the rear O2 sensor:
https://www.i-club.com/forums/showth...hlight=cel+fix
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
WRC_Scooby
Jul 31, 2004 04:01 PM
BADWRX
Apr 19, 2003 02:47 PM
