how much boost
Old Oct 21, 2003 | 12:07 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
most people you hear trying to run 18+ psi are also the same people that are trying to put everything back to stock to get the dealership to fix their blown motor
put 2 and 2 together 15-16 PSI is safe, I would not go anymore then that
Old Oct 21, 2003 | 01:04 PM
mmboost's Avatar
I shoot for 15.5psi and limit at 16.0psi. I have tried, when I've had juice in my tank, to shoot for 16.0 and limit at 16.25... pretty much every time after a few good runs, timing got pulled and things got sluggish. I'd back off a bit and after a while things got happier again. It seems everyone's car varies a bit. But for the most part, mostly stock cars are really happy with a 15.5 peak.
Beware - some WRXs have been known to ping with stock boost or less than 15.0 when trying to raise it. Don't push it if you hear pinging or wonder why the car feels like a dog after you raised boost. Tune SLOWLY. SMALL INCREMENTS. Its not as pleasing to tbe butt-dyno... but as Scott eludes to, its pleasing to the wallet.
jason
Old Oct 21, 2003 | 01:44 PM
Magish's Avatar
Definately keep it at 16 or below or risk seriously hurting your engine.
CHeers
-Jeff
Old Oct 21, 2003 | 07:58 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
boost it up! Mad powa y0!
Keep it at 15. Don't touch it until you've read Corky Bell's "Maximum Boost." This book will set the groundwork for anything you learn about turbocharged cars from here on out.
Old Oct 21, 2003 | 09:40 PM
mmboost's Avatar
One thing to always remember while reading Bell's excellent book is that he's mostly dealing with larger displacements and lower boost levels. (He often refers to anything above 7 or 8 as quite high). Except for a little caption about an Integra engine, the smallest he discusses really are => 3.0L Supras. Its the theory that counts with Bell's words... not the numbers.
jason
Old Oct 22, 2003 | 08:01 AM
Jgrahn555's Avatar
Sarcastic Jackass
Indeed!
Old Oct 22, 2003 | 11:26 AM
mmboost's Avatar
Hey that's postwhoring!
[edit: hahaha now respond by saying "indeed!" hahaha]
Old Oct 23, 2003 | 01:26 AM
Daredevil's Avatar
im about to buy the greddy profec b spec 2, so i should put it at about 15.25 psi? btw i have helix up and down pipes on my 03 sedan. ^^^ that psi level will be safe for the most part yea? and how much of a gain will i feel?
(i ran a 14.3 tonight) though i hardly go to the track, im all for back road twisties
Old Oct 23, 2003 | 01:31 AM
Daredevil's Avatar
and
when you say small increments
does that mean i set my boost at 14 psi for a day? or just for a trip around the block, then put it to 14.10? or 14.25? and then another drive around the block? or drive with 14.25 for a day? then keep doin that until 15.5 or so?
yzercyber
Aug 12, 2005 03:42 PM
skimobile
Jul 28, 2005 07:14 PM
antdiesel3
Nov 8, 2004 02:56 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
