Cel p0546
Old Aug 3, 2010 | 12:17 PM
kmason14's Avatar
Car Info: 2005 Subaru WRX
Cel p0546
Hey all I just bought a 2005 WRX about a month ago and noticed the CEL came on a few days after buying it. Concerned, I took it home and scanned it to find just one code - P0546, the infamous EGT sensor code.
Now, the guy who had the car before me had an exhaust system on the car, and I assume he had a catless up-pipe at one point, which probably burned out the EGT sensor. Also, I have noticed my peak boost only goes to about .08 MPa which is about 1-2 psi lower than it should be, and I have read about this same situation here : http://forums.nasioc.com/forums/arch.../t-269651.html
Does any one know the procedure for probing the EGT sensor with an ohmmeter to test if it is burned out? Or should I just go ahead and do the 2.2K resistor fix? ORRR should I go buy a new sensor and put it in (assuming I determine the old one to be bad).
Any advice is much appreciated
thanks
Old Aug 4, 2010 | 12:18 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Does the car have an aftermarket UP? If so, you should just install the resistor or get a tune that will clear that code. If its the stock UP, I would highly recommend replacing it as the EGT sensor and UP cat can fail and take out the turbo eventually.
-- Ed
Old Aug 5, 2010 | 08:55 AM
kmason14's Avatar
I'm pretty sure he put the stock up-pipe and everything back on, although I am waiting to here from the guy to confirm 100%. The EGT probe is definitely in there, and i put the resistor in for now. So you're saying if it is the stock up-pipe that I should replace the EGT sensor? Or replace the up-pipe?
thanks for the help
Old Aug 5, 2010 | 11:27 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
thanks for the help
I would replace the stock UP to get rid of the pre-turbo cat.
-- Ed
1wrx2goplz
Jun 2, 2004 02:35 PM
Sonic Boost
May 17, 2004 10:24 AM
smokinthunder
Dec 31, 2003 09:24 PM
BigDRex
Dec 27, 2003 02:15 PM
v1rus67
Jun 30, 2003 10:06 AM
Top
