Please Help..CEL code P0546
Old Dec 31, 2003 | 11:40 AM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
What is the CEL fix? It stops the rear CEL code P0420 Catalyst System Efficiency Below Threshold from appearing, this code being caused by the lack of a catalytic converter in the downpipe. This is usually fixed with a Pony Express MIL Eliminator or similar fix. Ensure you obtain the correct type for your model year as there are two types: 02/03 and 04. ***NOTE*** There are two CEL fixes for the WRX, the other one is the 2.2 KOhm 1/2 watt resistor. It is used to combat the CEL code P0546 = Exhaust Gas Temperature Sensor Circuit Malfunction (High Input) in the uppipe. This notice, though not important to this thread, acknowledges there are two "CEL fixes" and defines them individually to avoid possible confusion.
This is a quote taken from here.
Hope this helps out.... good luck
-Ted
Old Dec 31, 2003 | 09:24 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
thanks ted for that link. it cleared some stuff up
El
Jun 25, 2007 08:20 PM
Wingless Wonder
Mar 22, 2005 12:07 AM
1wrx2goplz
Jun 2, 2004 02:35 PM
v1rus67
Jun 30, 2003 10:06 AM
zeke79
Jan 22, 2003 08:54 AM
