Boost Levels
Old Mar 31, 2004 | 02:26 AM
wonton2049's Avatar
Car Info: 2005 STI
Question Boost Levels
Just wondering if someone could tell me what the boost levels are for a stock WRX in each gear and at what RPM's. For example, 1st gears max boost would hit X psi at X rpm's and 2nd gears boost would hit X psi at X rpm's.
the problem is that i dont really push the car that much but when i do, i dont think i really see the boost gauge hit 1 bar. kinda getting me worried. all i have is an UP, DP, and catback. any help would be appreciated. thanks.
Old Mar 31, 2004 | 02:43 AM
Wingless Wonder's Avatar
Moved from General forum.
Old Mar 31, 2004 | 04:39 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
There are several factors that could change the answer to your question (engine load, altitude, etc). It's not simply X psi @ X rpm's in X gear. With that said, (speaking loosely of max boost) I've seen some folks claim that they never could reach 13+ PSI in 1st and 2nd gear, while other WRX owners claim they could (myself included). I don't know what effects your mods would have on the levels. Hopefully someone with more insight will chime in.
- Kean
Old Mar 31, 2004 | 05:43 PM
wonton2049's Avatar
Car Info: 2005 STI
i forgot about the whole altitude thing. well... i just looked it up and the elevation where im at here is 585 feet above sea level. now, i hope that this is suppose to be a good level to be at for optimal boost.
The problem is that i would hit about .7 or .8 bar and then drop down to about .5 or .6 bar and remain there. if no one has any suggestions, can some one provide me a pic of their turbo hoses just so that i can compare with someone elses whos boost level is normal? thanks again.
Old Apr 1, 2004 | 04:50 PM
wonton2049's Avatar
Car Info: 2005 STI
hmmm... does peak boost hold for a while or does it just taper off? if it tapers off... can someone tell me when it begins to drop?
wonton2049
Oct 24, 2004 07:01 PM
02silversuby
Jun 21, 2004 11:40 PM
Slamsitin
17
Sep 20, 2003 12:32 AM
turborambler
May 30, 2003 08:07 PM
spdkills
Dec 26, 2002 07:33 PM
