Boost leak
Old May 7, 2005 | 08:26 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
Boost leak
I'm running on a vf34 setup with accomdating mods like borla exhaust manifold, helix up and down pipe, borla cat back, pink injectors, and walbro fuel pump. I've been tuned by mike to boost at 17.5 psi. It has now been almost two months since the tune, and i don't know if it's been like this or if it just happened recently but my boost gauge is registering my max boost at .11 MPa, ( which is almost 16 psi) so i'm thinking i have a boost leak somewhere. The problem is i don't exactly know of a way to find where the leak is. If anyone have any good ideas of how to find where the boost leak is please let me know Thanks a lot guys.
Henry
Old May 8, 2005 | 08:28 AM
SubyWRXdude's Avatar
Are you able to hear the leak from anywhere?
Old May 9, 2005 | 01:16 AM
Car Info: SGM 135i
no ><, i'm thinking that it's my exhaust manifold. I've just gotten a used Borla ceramic coated exhaust manifold put in, and that's when i checked my gauge and noticed a loss in boost, so iono. i'm gonna go under the car and check to see if there's a leak there .
Old May 9, 2005 | 08:41 AM
that would be a good place to start, making the gasket is bad or a hole in the manifold, chere there first
Old May 9, 2005 | 11:19 AM
mbquarts's Avatar
Car Info: 03 MBP WRX
Do you feel like you have lost power? Maybe your boost gauge is not reading correctly. It sounds like you have the stock boost gauge(mpa)...that could be the problem.
Old May 10, 2005 | 10:23 AM
NeRdY DoRkUs's Avatar
yea when u change manifolds or pretty much any joint you probably will get a leak.
one trick to solving that problem is when you install or get new gaskets torque it to spec after your done. turn on the car and wait for it to warm up completely. drive it down the street and back. come back to the garage and retorque all the nuts and bolts. this will seat the gasket and create a seal beacuse the metal is already expanded as much as possible
hope this helps
Old May 10, 2005 | 08:51 PM
Car Info: SGM 135i
thanks a lot guys, i'm gonna get new defi gauges soon so maybe that will change things .. we'll c ... my ra gearset is going to be installed too
Old Nov 21, 2005 | 07:50 PM
Twenty36_1's Avatar
Car Info: soon to be wrx
I also have a similar problem, but rather than start a new thread I figured I would post here.
I have a 02 wagon with a Vishnu Stage 2 kit (VF34, pinks, TBE, Pulley and ECU). My autometer boost gauge only reads 12psi. The gauge was on the car when I got the car so I have no idea where to check to make sure the lines/hoses are properly connected. I also tried the Valet reset and that did not help. Any ideas? Would an exhaust leak in the UP cause a loss of 4-6psi? The gauge also reads a steady 12psi.
Anyone wanna help me fix it/find the problem for a 6 pack?
Old Nov 22, 2005 | 01:58 AM
AzN121184's Avatar
Car Info: civic
a leak in the uppipe would definitely cause the 4-6psi loss in boost.
Old Dec 19, 2005 | 07:08 AM
Jdem18l's Avatar
Car Info: 2002 wrx
i had a boost leak last week i wasnt losingalot of peak boost but my throttle response and spoll up waslacking a little bit. i had a slit in my hose connecting my topmount. once it was replaced throttle response was so much beter take a mirror see if you can see any cuts in your silicone intercooler duct hose.
vayrogar
Mar 16, 2012 07:45 PM
snaggleto0th
Sep 12, 2010 09:54 PM
brucelee
Aug 2, 2010 09:39 PM
ScoobyRoo20
Sep 9, 2003 04:43 PM
bigdaddy
Jul 10, 2003 12:09 PM
