boost gauge vacumm???
Old Jan 28, 2004 | 01:18 PM
DarkAngel's Avatar
boost gauge vacuum???
So I had my car for a while and when I first installed my blitz dtt with boost gauge I remember it reading -.60 Bar ( I guess) at warm idle. Well the car was in a accident and they replaced heads and valves and not it reads at warm -.67 or even -.70 at idle. The peak boost seems to be fine. what do you guys think the problem is. I checked the lines but they all seemed fine
Old Jan 28, 2004 | 02:05 PM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
If the needle is steady and you guage is accurate and the numbers are were you say they are your manifold gaskets might be leaking or you may have a broken or damaged vaccum hose.
I would take it in to have it checked.
I just checked the tech docs and .60 bar is where the needle should be.
asoka05
Aug 1, 2011 07:05 PM
cdawg
Jan 4, 2008 03:44 PM
IS300
Nov 18, 2003 05:25 PM
mattr762
Apr 18, 2003 09:12 AM
