boost gauge?
Old Nov 28, 2005 | 09:52 PM
pablo_her's Avatar
Car Info: 08 silver sti
boost gauge misread? or is this a correct reading? please help.
i just had some autometer c2 gauges installed well my question is that when i put the pedal to the floor in 3rd gear throw 5th my gauge will climb to say that pushing about 25 - 27 psi. is that correct? i have a stock turbo, i thought stock psi for wrx is about 13.5? am i getting a miss read?
05 wrx.
Old Nov 29, 2005 | 12:16 PM
BillJC's Avatar
Car Info: 02 WRB WRX
most definitly not boosting that much. Are you sure it's hooked up correctly?
Old Nov 29, 2005 | 01:31 PM
pablo_her's Avatar
i had installed for me at superautobac in so cal. it was done professionally.i think i am goin to have to take it back. and have them look at it. i read in another post that some stock wrx's push more 20+ psi. i tried looking for but now i cant find. and i just read it yesterday.
Old Nov 29, 2005 | 01:46 PM
mbquarts's Avatar
Car Info: 03 MBP WRX
What is the gauge reading when you are at idle? It should be a negative number...At full boost you should get 13.5 psi.
What units is the gauge reading in? A normal gauge would be in psig...which is gauge pressure. If it is reading in psia it could be correct. Psia is atmospheric pressure...so basically it is psig + 14.7psi. To convert you would need to subtract all your readings by 14.7.
Old Nov 29, 2005 | 01:55 PM
pablo_her's Avatar
well the gauge i have is a boost/vac it reads psi, but i have no idea if it is psia or psig this the gauge that i have (http://www.autometer.com/cat_gaugede...earch&gid=2486). when i am at idel it sit at about 5-10 in. hg. sometimes lower.
Old Nov 29, 2005 | 03:34 PM
mbquarts's Avatar
check to see where they installed the t-fitting it should be coming off of the small vacuum line attached to the by pass valve.
Old Nov 30, 2005 | 08:17 AM
pablo_her's Avatar
i couldnt find any t fittings. but i did see this which wasnt there before. it seems to go where the vacum hose of the by pass valve go to. you see what i am talking about? those 2 hoses with silver connecters. and then the regular hose below that. and that metal attachment that they are connect to.
Old Nov 30, 2005 | 09:34 AM
mbquarts's Avatar
Well...those lines with the silver fittings are fuel lines. I'm not sure what those fittings are for...
The boost gauge vacuum line should be tied into the vacuum line coming out of the by pass valve that you took a picture of. The installer must have tied it into another vacuum line some place else.
The line for the boost gauge should be coming out of the firewall right behind the intercooler. Take a look and try to trace it back to where they installed it.
Old Nov 30, 2005 | 09:39 AM
pablo_her's Avatar
did they add these lines? i dont think i seen them there before?but they all go towards my fire wall right next to the strut. then i am thinking that the bottom hose with out the silve cap is my vacum hose. i dont know.
Old Nov 30, 2005 | 11:08 AM
mbquarts's Avatar
Those are all fuel lines.
Click on the installation instructions for the boost gauge...
http://www.subaruparts.com/catalog/?section=621
Old Nov 30, 2005 | 11:16 AM
pablo_her's Avatar
the installation page wont load
cdawg
Jan 4, 2008 03:44 PM
NeoTrunks
Dec 23, 2004 07:31 PM
IS300
Nov 18, 2003 05:25 PM
mattr762
Apr 18, 2003 09:12 AM
