Boost
Old Mar 25, 2004 | 02:02 PM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
Boost
I know that everyone says that you can safely run 16psi on a stock wrx. Why is this? If i were to upgrade my fuel injectors, fuel pump, and fuel management system could i run say 20psi on my wrx? Or do they say only 16psi because of the internals?
Old Mar 25, 2004 | 03:54 PM
NluvwithXLR8ing's Avatar
If you upgrade the fuel system, and get it tuned you shouldnt have too much of a problem running more boost. The problem occurs when somebody increases boost but does not change anything else to accomadate it.
Old Mar 26, 2004 | 01:36 AM
no. the stock turbo sucks thats why you cant. it cant hold more than 16 LBS stock. the turob also become inefficient after 15 lbs
Old Mar 26, 2004 | 06:20 AM
Originally posted by AWDrBelong2US
I ran 22lbs of boost on the stock turbo (stuck wastegate), it was a fricken rocket, till it hit the fuel cut off.
For how long, didnt that cause alot of damage?
Old Mar 26, 2004 | 12:29 PM
liquid_sword's Avatar
Car Info: silver 03 rex
damn yes im wondering to. what happend to your car with 22lbs of boost..??
Old Mar 26, 2004 | 01:36 PM
esracer's Avatar
Car Info: 2002 Honda S2000
All I can say about that is OUCH!!
But yeah once you get over 15psi the turbo will not be that efficient, yes you will be make more power with the increase of psi but not as much as you would be with a bigger turbo.
Old Mar 27, 2004 | 07:06 PM
1tyme's Avatar
From: mr. police officer,im not as think as you drunk i am....
Car Info: 02 wrx
guys, i thought that fuel cut was at 13.7psi
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
