Boost
Car Info: Silver 2002 WRX
Boost
I know that everyone says that you can safely run 16psi on a stock wrx. Why is this? If i were to upgrade my fuel injectors, fuel pump, and fuel management system could i run say 20psi on my wrx? Or do they say only 16psi because of the internals?
If you upgrade the fuel system, and get it tuned you shouldnt have too much of a problem running more boost. The problem occurs when somebody increases boost but does not change anything else to accomadate it.
Originally posted by AWDrBelong2US
I ran 22lbs of boost on the stock turbo (stuck wastegate), it was a fricken rocket, till it hit the fuel cut off.
Car Info: 2002 Honda S2000
But yeah once you get over 15psi the turbo will not be that efficient, yes you will be make more power with the increase of psi but not as much as you would be with a bigger turbo.
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
XwrxX
Dec 17, 2002 07:14 AM
