Better turbo t-67 or GT3037s?
Old May 2, 2003 | 07:38 AM
1quikrex's Avatar
From: Perrin Race DP Perrin Up-pipe Blitz Nur-spec CB Blitz LM intake TXS UTEC GFB BOV
It depends on what trim you are going to use on the 3037. The T67 is probably the bigger power turbo at the expense of lag, the 3037 with a .64 A/R will probably give you full boost like 1000 RPM's sooner than the T67. Either turbo you go with is going to produce massive power you just have to decide if you are going to need all that power.
Old May 2, 2003 | 03:01 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Those "turbo calculators" are the most silly thing since cheeze-wiz.
3037S is a great turbo.
I personally have the T67 with 10cm^2 exhaust housing. On the 2.0L non-AVCS that turbo is an overkill.
I was able to make 300 shiv's HP on ~94 octane.
However, the lag was bad. I opted to get a 2.4L higher compression motor with AVCS STi heads to make the T67 more happy.
However, if I could do it all over again, I would get the 3037S or 3037R.
HKS turbo's are superb and they spool up hella fast and make great peak power.
Hope this helps.
Drift My WRX
May 8, 2006 11:08 AM
NothingToLoose
Apr 18, 2004 06:57 PM
SFPD1610
Dec 17, 2003 12:12 AM
STi-Fever
Nov 17, 2003 07:39 AM
in3g_wrx
Aug 7, 2003 05:27 AM
