Best mods for WRX?
Old Jul 6, 2004 | 11:21 AM
esracer's Avatar
Car Info: 2002 Honda S2000
Best first mod, go catless
Old Jul 6, 2004 | 11:54 AM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
For starters with Power= uppipe, downpipe, intercooler hoses, Cat Back.; your goanna have to pull the intercooler and downpipe to install the uppipe as it is so you minus well do them and save yourself the labor later. Plus you can get a desent DP for around 200. The Samco hoses go for around 128.
For starters with Suspension= Rimz, good tires, rear anti-sway, strut tower braces; There are tons of cheap Rim/Tire combo packages out there..i.e. look at Roto's. In my oppinion there is way to much body roll under hard corning.. go to an adjustable rear sway with links... this will flatten it out a bit. (Watch out for oversteer) . Strut tower braces are a cheap way to get back a little chassis regidity... and its an easy intall. You can address the coil over / spring expense later... i have Eibacks now only becasue a friend gave me a pro set new but eventually ill go coils, probably Leda's,....all in all its a world of difference but only needed really if you plan on tracking it or live in an area that you can certainly take advantage of it.
I'm waiting to do my TMIC b4 I do engine managment... either XEDE with software or Accessport. I want to be able to tune it after most of the bolt ons are done.... minus the turbo....
just my 2$....
FYI... doing the TMIC because a buddy of mine did the FMIC and parked it in the city overnight only to come back to a destroyed front end..... insurance did NOT cover it. Since this is also my daily driver i dont want to risk front end damage with a FMIC that insurance wont pay for... not to mention the lost labor considering most OEM body shops wont touch heavily moddified cars.
Old Jul 6, 2004 | 01:14 PM
esracer's Avatar
You do not have to remove the intercooler to replace the Downpipe and uppipe, I replaced both without touching the intercooler.
Old Jul 6, 2004 | 01:34 PM
willow's Avatar
Car Info: wrx02
Originally Posted by Littleboyblue
Did you notice a big difference with these mods? And what kind of differences?
I did notice a big difference. Quicker transfer of power to the ground I would say. Noise level increased in a good way. Sounds like a electric car....
Old Jul 6, 2004 | 02:58 PM
nic3krnnamja83's Avatar
i think pretty much any mod besides a intake would be a plus
Old Jul 7, 2004 | 09:21 AM
Kwilson21's Avatar
This is true... unless you have to alter the turbo heat shield for a relocated EGT bung on the new uppipe as is the case with Perrin.
-K
Old Jul 7, 2004 | 10:18 AM
raazin's Avatar
Car Info: 2002 wrx wagon black
headers
Old Jul 8, 2004 | 10:38 AM
AzN121184's Avatar
Car Info: civic
a friend once told me this when i asked him the same question:
"stop, turn, then go"
brakes, suspension, then power.
If i had a chance to redo my car, i'd be doing it that way.
Old Jul 12, 2004 | 11:39 PM
raazin's Avatar
if you want power get the uppipe and downpipe and a mbc good luck
carman_subaru
Cars For Sale
Oct 29, 2003 06:28 PM
Slamsitin
Jun 17, 2003 09:29 PM
djcttb
Apr 29, 2003 08:23 PM
mmboost
Apr 3, 2003 10:46 AM
