Minimal mods, best octane rating?
Old Jan 22, 2003 | 03:24 PM
mmboost's Avatar
With Vishnu IC hoses, HKS Hiper, no resonator, and an EBC limiting to 15.7psi I've been wondering what's the best octane to use? When I say "best" I mean two things. 1) Prevent any damage, although on 91 I have not heard any pinging, although I have experienced some timeing retardation. 2) What will make the ECU happiest in letting me use my mods and 15.7 to the fullest?
I'm in SFBA with basically one choice in gas quality and price: 91 @ $2.00/gal ... either that or burn 1/2 a tank to find something better. So, I'm going to start mixing toluene. From what I have read up on, it seems that I really do not need that much. With 2 gal of 114 rated toluene I can hit 93.9 on a full tank complimented with that nasty 91.
jason
Old Jan 22, 2003 | 07:14 PM
Mindspark's Avatar
Yes, toluene is teh cool.
I think a mix of toluene, ethanol and automatic transmission fuild is what I will run in the long term but I'm still doing research. Ethanol will make the gas burn even cleaner while providing a little more octane boost. ATF acts as a cleaning agent for the fuel system.
I plan to run with just 1 gallon of toluene + 1/2 quart of ethanol + 2oz of ATF / full tank of 91 octane on a regular basis. ~93 octane. I think this would be the ideal mix.
I noticed some timing being pulled on 91 gas with my VS1 so I ran 2 gallons of toluene in 3/4 tank of 91 this weekend and it made a huge difference. I need to borrow a local datalogger and get some hard data. :P
-Bernard
Old Mar 20, 2003 | 11:32 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
Try Alcohol injection. It lets you run lower octane gas such as 91-94 and get the effects of 100. I have it on my 1987 Grand National (turbo 3.8 V6 w/21lbs of boost). Runs great and makes a noticible top end. Also cleans up you engine internals. I don't have it on my WRX but will soon. Also you can get Alcohol (rubbing alcohol) for a hell of alot cheaper than 110 octane and a computer runs the SMC system so its safe for daily use. Check out the site for more info. http://www.geocities.com/rad87gn/tech/SteveCkit.html
LIT4
Feb 13, 2004 04:51 PM
awd4ever
Aug 26, 2003 03:56 PM
awd4ever
Aug 25, 2003 08:36 PM
