Autometer Boost Gauge Prob
Old Jan 8, 2004 | 10:51 AM
skoobywrx's Avatar
Car Info: 05STI/05Leg
Unhappy Autometer Boost Gauge Prob
Just installed the Autometer boost gauge.
Everything was fine.
engine at off is at 0psi
idle -14psi
at wide open its about 8-9 psi
wheres my other 5?
my car feels fine before and after the gauge install
mods,
Turbo XS TH BOV
K&N Typhoon(i know i know, but hey, it was free for a mock from K&N)
axle back
I ver read and searched for some items.......but no clear answer
would the nylon tube connection have a problem? kinks in the tube? Im gonna switch to all rubber tubes tonight....any other things you can think of?
Old Jan 8, 2004 | 11:16 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
If you had a kink I don't think it would be reading as well as you have described. It's 8-9 psi in all gears?
Old Jan 8, 2004 | 12:05 PM
skoobywrx's Avatar
no its lower at 1st and 2nd, i checked it while i was at lunch,
its has a big kink and the gauge its self. like a complete 90deg pinch at the gauge, ill try that first.
Old Jan 8, 2004 | 12:49 PM
04blkWRX's Avatar
Well, it looks like you've found your problem. The kinking hose is 90% of my motivation to switch to an electrical boost gauge.
Back in my mechanical days I ended up wrapping the tube with tape from the back of the gauge down a few inches. This was my homemade stress reliever to stop the nylon from bending over a corner of the brass fitting.
Old Jan 27, 2004 | 01:41 PM
skoobywrx's Avatar
still no fix in that........
it may be a bad wastegate solenoid, or a bad vaccum hosing, or a bad gauge, i dunno
Old Jan 27, 2004 | 02:09 PM
RussB's Avatar
Car Info: $200,000 sports car
are all the hoses on from the turbo to wastegate and solenoid installed properly?
Old Jan 27, 2004 | 02:31 PM
Salty's Avatar
interresting... my autometer works fine
Old Jan 27, 2004 | 02:49 PM
ilivas's Avatar
Why are you getting 14 psi at idle?
Old Jan 27, 2004 | 04:12 PM
RussB's Avatar
that's a common boost gauge mistake... it's probably more like 14 in hg of vaccum at idle, which is just about right.
Old Jan 27, 2004 | 04:21 PM
DizzyWRX's Avatar
I hope this isn't a common problem with autometer. I was thinking about getting some.
Old Jan 27, 2004 | 05:37 PM
ilivas's Avatar
I have an autometer sport comp and mine works great.
Old Jan 27, 2004 | 08:01 PM
amelnikov's Avatar
Car Info: 2002 WRX Sportwagon 292WHP
Recheck your lines, you should be gettin about 20 inches of vacuum at idle. I had the same thing a while back, it was a pinched line that did it.
Alex...
Alex Performance
Old Jan 28, 2004 | 02:17 PM
SnoHumper's Avatar
Car Info: sc300
if you didnt reprogram your ecu or use a boost controller you will only hit 9psi in 1st and 2nd gears. sucks huh?
gesundlich
Dec 27, 2005 05:05 PM
Shaitiger
Mar 28, 2004 02:20 PM
dr3d1zzl3
Feb 22, 2004 06:41 PM
IS300
Nov 18, 2003 05:25 PM
Chronos
Oct 27, 2003 08:17 AM
