AEM Short Ram CEL problem
Old Jan 30, 2003 | 02:51 PM
blitzoid's Avatar
Car Info: 2002 WRX Sportwagon, MBP
Assuming you did the install properly:
Try resetting your ECU... that should solve it. The problem lies in the sheer quantity of air that the engine is seeing, which it wasn't before.
to reset the ecu - disconnect the negative battery terminal... depress the brake pedal a few times, wait 5 minutes or so, and then reconnect the battery. The car will idle horrible for 20 seconds or so, and then once the ECU realizes how much air it's seeing, it should get smoother.
Let the car idle for 5-10 minutes, and then go for a drive.
(this is, of course, assuming that the CEL goes away)
Old Jan 31, 2003 | 11:20 AM
mmboost's Avatar
read this thread:
https://www.i-club.com/forums/showth...&threadid=7657
Sell the intake and do something more worthwhile for your car. Those power increases are most likely psychosomatic
jason
Old Apr 13, 2003 | 05:52 PM
4080wrx's Avatar
I have a aem cai on my 03 wrx. I have only seen the check engine light once (knock on wood) and that was after installing the cai. All i did was reset the ecu and no problems. Its been about 3000 miles now and no reoccurence of the cel.
4080
Old Apr 14, 2003 | 01:49 PM
4080wrx's Avatar
KavalaQ
Just a suggestion do you think maybe you damaged the mass airflow sensor when you removed it. That could be causing your problem.
4080
rayray888
Sep 13, 2005 07:57 PM
1WRX2NV
Mar 19, 2003 03:28 PM
SbRCR267
Mar 13, 2003 09:51 PM
SbRCR267
Mar 7, 2003 06:45 PM
sCream
Jan 24, 2003 07:01 AM
