AEM Short Ram CEL problem
My 2003 WRX has no mods yet other than the AEM short ram. As soon as I installed it the Check Engine Light came on. I ran the code through a scanner and it reads bank one lean. Also my idle speed dropped to just under 500 RPM.
Any help at all would be greatly appreciated.
The system is fully secured and tight and the MAF is not on backwards or dirty.
Car Info: 2002 WRX Sportwagon, MBP
Assuming you did the install properly:
Try resetting your ECU... that should solve it. The problem lies in the sheer quantity of air that the engine is seeing, which it wasn't before.
to reset the ecu - disconnect the negative battery terminal... depress the brake pedal a few times, wait 5 minutes or so, and then reconnect the battery. The car will idle horrible for 20 seconds or so, and then once the ECU realizes how much air it's seeing, it should get smoother.
Let the car idle for 5-10 minutes, and then go for a drive.
(this is, of course, assuming that the CEL goes away)
well i've driven it extremely babied for about 20 miles thus far and tomorrow will open it up and see if it comes back but so far so good.
Status report: About 10 miles into my drive today at 2500 RPM's that beautiful yellow light shown bright once again. It took longer for it to come on this time than in the past but it's still there.
read this thread:
https://www.i-club.com/forums/showth...&threadid=7657
Sell the intake and do something more worthwhile for your car. Those power increases are most likely psychosomatic
jason
jason
I installed the same intake on my 03 wrx with a borla exhaust and got the same problem. I reset the computer a couple times by dissconecting the battery and it always comes back. Today i had it reset with a code puller. So we will see. Id also like to know of any fixes for this problem.
I have a aem cai on my 03 wrx. I have only seen the check engine light once (knock on wood) and that was after installing the cai. All i did was reset the ecu and no problems. Its been about 3000 miles now and no reoccurence of the cel.
4080
4080
After months of research and trial and error on this one i have no answer for a proper fix. AEM refuses to do anything for me unless i bring the car to them. They inspected my system and it is in fact within spec. No matter what you do to clear that code it will come back after only a short time driving. Thw WRX doesnt take well to many different intake systems because the Mass airflow sensor is sensative. If you wanted to spe3nd the money amyway, a piggy back ECU might fix it. By the way the code is most likely reading bank one lean.
Here what I have neded up with as my solution. I am selling my AEM short ram and replacing it with the stock box and a drop in K&N and removing the resonator box. Simple as that. Only a few WRX's have this problem so most likely if you sell it to someont it will work fine.
As we have seen from many other people after market intakes are notorious for causing CEL's. My suggestion is to buy that thingy (technical name) that prevents the CEL light from coming on. Simply resetting the ECU will not do nothing more than waste your time. And thats the gist.
Ryan
Ryan
The question then would have to be is the CEL legit. Is my engine actually running lean. Also if you use any device (or for those who are really cheap black tape) to prevent the CEL from coming on what other potential problems are you preventing yourself from seeing? I'd have to say i dont think thats a good idea.
KavalaQ
Just a suggestion do you think maybe you damaged the mass airflow sensor when you removed it. That could be causing your problem.
4080
4080
I swapped it back out with the stock box and the problem went away so Ill say its not the Mass Air Sensor.
The AEM is now gone and the K&N is in. Recomendation for those who follow the same path is make sure you dont over oil the filter or you will screw up your Mass Air Flow Sensor.
rayray888
Sep 13, 2005 07:57 PM
