? about my manual boost controller
Old Jan 24, 2005 | 11:56 PM
2K3WRX808's Avatar
Car Info: Sonic Yellow 03 Wrx =blitz fmic,blitz intake,turbo xs boost controller,hks ssq bov x2,apexi exhaust
i have a turbo xs manual boost controller and since i put it in i can tell the turbo spools more stronger now , but when i pound the car down the street or somthing the rev limiter stops me @ like 6 grand or less somtimes ?? why does it do this??? i turned the controller 2 1/2 turns +
Old Jan 25, 2005 | 12:49 AM
You're probably hitting fuel cut from overboosting. I REALLY hope you have a boost gauge on hte car. Let us know what your peak boost is.
More importantly, make sure you're never in positive boost with less than ~75% throttle. If you are, you're running boost with very lean A/F ratios, also called Partial Throttle Full Boost (do a search for "PTFB"). When you are below ~60% throttle, the ECU is operating in what's called "closed-loop" mode (another search to do). In that mode, it's using the O2 sensor to try to run 14.5:1 A/F ratio, which is far too lean under boost. What happens is you get very high EGTs, detonation, and eventually your motor blows up.
Old Jan 26, 2005 | 01:23 AM
2K3WRX808's Avatar
i do have a boost gauge and the gauge reads high when i just cruizing so i thought it might be broken and in accurate but i could be wrong ?? so what should i do ? turn the boost controller down ? thanks for the reply !
Old Jan 26, 2005 | 01:44 AM
Well, what is "high" How much boost pressure are you getting? Assuming you have a stock turbo, You shouldn't be reaching mroe than about 16.5 psi peak, tapering off to 12 at redline (which you probably aren't, with an MBC). And the gauge isn't ever going to read high- if it breaks it will read low. The high reading when cruising means you're getting PTFB- I would pull the MBC out if I were you, and go get an EcuTek reflash, which prevents that from happening. Cobb AccessPort is also a proper solution if your mods match a Cobb-generated tuning map.
Short answer: yes, turn down the MBC if you're getting more than 16 psi, but you'll still be getting PTFB regardless.
Old Jan 26, 2005 | 03:38 PM
The OLM is even harder to fine tune correctly than an MBC is in the first place. Plus, I personally wouldn't expect the ECU to be properly mapped for the early open loop. It's still a hacked solution that is much better resolved with a reflash.
Old Jan 27, 2005 | 07:18 PM
2K3WRX808's Avatar
Thanks For The Reply's Well I Guess Ill Turn Down The Boost Controler 1 1/2 Turn - Or Maybe Just Take The Darn Thing Out .....thanks Alot Ban Suv's
Old Jan 30, 2005 | 12:17 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
What gave you the idea that the OLM is hard to fine tune... or even requires any tuning at all for that matter? In fact the OLM is a passive device with no user adjustable parameters at all and works just fine with most MBC's. Also, FYI, the stock fuel map is mapped just fine from very low load up to full load through all RPM's and runs appropriate a/f levels for widely varying boost levels in open loop. It may not be as advanced of a solution as a reflash, but its much cheaper and does allow one to safely and smoothly run an MBC with the stock ECU.
-- Ed
Equilibrium Tuning
EQTuning.com
Old Feb 2, 2005 | 09:13 PM
rollinDAwrx's Avatar
Car Info: 2005 WRX Black
where can i get a OLM from and how much? i have a 05 wrx with a mbc on it and if i turn up the boost anywhere near 15 psi or higher the engine detonates, so i know the car isnt get enough fuel! thanks
Old Feb 2, 2005 | 09:41 PM
FiDRcr's Avatar
Ed I also want to know when your coming out with a 04-05 OLM unit for the WRX.
~luke
Old Feb 2, 2005 | 10:17 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Hey guys... the 04-05 OLM poses a completely different challenge than the 02/03. For the 02/03 ECU, spoofing the TPS signal makes it possible to force the ECU into OL instantly. This is not so for the 04/05 ECU's since it has the long dellay. I have a couple of ideas, however, but it'll take a little experimentation to figure it out, but there's still hope.
-- Ed
Equilibrium Tuning
EQTuning.com
Old Feb 2, 2005 | 10:27 PM
Group B's Avatar
Dahveed aka Robin Hood
um have you ever driven in a car with an OLM installed?
Old Feb 6, 2005 | 11:54 PM
FiDRcr's Avatar
ED.......my friend is trying to get ahold of you and order a OLM unit. What is the best way to do this.
~luke
btw - he said that your email on EQtuning doesnt work
Old Feb 9, 2005 | 11:24 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
pm'd you
wrx46
16
Oct 29, 2003 01:07 PM
slvrwrx02
Sep 18, 2003 04:59 PM
Hidden Dragon
Apr 7, 2003 07:25 PM
IS300
Apr 7, 2003 05:31 PM
Kaos22B
Feb 18, 2003 07:14 AM
Top
