Manual Boost controller question
Old Mar 31, 2003 | 05:58 PM
killaho's Avatar
UTR Member
Car Info: 93 Impreza L
mbc's take about 5-10 min to install. You'll probably want to set it at 15.5lbs or 1 bar depending on how your boost gauge reads.
Old Mar 31, 2003 | 06:04 PM
bamfwrx's Avatar
Car Info: 02 WRX
15.5psi sounds like alot with an intake and no way to monitor exh temp
Old Mar 31, 2003 | 07:49 PM
killaho's Avatar
UTR Member
one of those days.... go 14.5
Old Apr 1, 2003 | 12:01 PM
roreswrx's Avatar
at first i also had a mbc on mine that a friend made. it worked great then i got a egt gauge. i was running about 16.5 psi in fifth. all stock motor and a cat back. i started to watch the temps so one day i took of the mbc to see the change in temps and ran stock boost it would hit about 12 psi in fifth gear. to my surprize the temps were only about 300 to 400 lower than running 16.5 psi. and that was only a few times for the most part they were the same. but i do think you should invest in a egt also.
Old Sep 18, 2003 | 04:42 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
One question i have concerning the install of the MBC is should I leave the stock boost control solenoid hooked up or should i unplug it. I know on my Talon I unplugged it with not problems.
Old Oct 29, 2003 | 08:23 AM
theworx's Avatar
Do any of you have any problems holding consistant boost? I am running the stock turbo and have the boost set at 16psi, however it normally doesn't hold there. It drops to about 14. How did you guys install yours? Did you install using the vacumm line going to the BOV as the source or come right off the turbo? I also have a boostvalve MBC and followed the directions that came with it.
