Installing the Replica Fog Lamp Covers
I <3 White Girls
What is the best way to install these things??
How do i know which bracket goes where?
also, once i get the bracket in place, whats the best way to put back the fog lamp bolt in??
Any Help would be apprecaited.
Thanks!
-Zoeb
Thanks!
-Zoeb
are they the mesh ones???--All u need is a screw driver---- if so it takes like 5 minutes just unscrew the bolt attached to the bottom of the fog light, you should be able to tell which bracket goes on what side by lining it up before you try to put it on, attach the bracket and screw it back on. Put the cover on if the screw that holds the cover on does not line up w/ the bracket just use a phillips head screw driver to bend ithe bracket to match up and that should be it... Hope it helps...Let me know
Car Info: 2006 Audi A3/2007 Civic Si
Just in case, the bracket should be upwards. One of the brackets may go in easily, but the other will not line up most of the time, so some bending may be required.
Be careful not to scratch the car!
Zoeb2s
Oct 7, 2004 10:18 AM
