91 legacy turbo...ideas for mods
Old Sep 2, 2008 | 12:21 AM
wrxisthebest's Avatar
can someone answer my question?
how can u uise ej20 heads with out having to use the wrx harness?
will u have to change fuel imput?
or pressure, and how would i work correctly
since hardware89(casey) is a good friend of mine, i would like to be able to help him out, and without answers i won't be able too...
Old Sep 2, 2008 | 12:28 AM
pics of the car!
Old Sep 2, 2008 | 08:30 AM
ipozestu's Avatar
Car Info: Broken Subarus
Originally Posted by wrxisthebest
howw can u run the ej20 head with no wrx harness?
It's quite simple, EJ20 crank spur, you bolt up the heads to the block, and start it up. There is no AVCS in the EJ20 heads. They are purely mechanical. The ECU won't even know you did something different. You will have to get some engine management, probably switch to a MAP sensor. I'm doing the same thing with n an EJ22T swap into my Porsche.
Old Sep 9, 2008 | 07:30 PM
ya, see i knew it wasn't just bolt in.. cause ur changing from 2 cams to 4 cams.. and the fuel and air input would be off... so in turn his AFR would be different, also, i think the SOHC heads actually flow better(so i've heard) so he would need a fuel controller...
Old Sep 10, 2008 | 08:17 AM
ipozestu's Avatar
It has no bearing. Timing is timing if you set your timing marks correctly it'll run just fine. Where do you get this stuff from? FWIW you'll never make as much power with an SOHC as you will with a similar DOHC...
Old Sep 10, 2008 | 12:15 PM
ok.. nvmthen
maximolegacy
Dec 6, 2008 02:09 AM
Jizzo_02SubiWRX
Mar 3, 2006 06:41 PM
4tirefire
Feb 10, 2005 01:01 PM
stevenkhau
Jun 6, 2004 02:07 PM
singsing
May 24, 2003 03:19 AM
