8000 rpm?
Old Oct 23, 2006 | 09:05 AM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
8000 rpm?
on a 02 wrx what is the stock valvetrain good to? can it withstand 8000rpms? right now i rev to 7500
Old Oct 23, 2006 | 09:09 AM
not for long
JDM sti yes
Old Oct 23, 2006 | 11:36 AM
codpiece21's Avatar
Car Info: 02 impreza wrx
6.5 is as high as i go, after that your just putting wear on the car.
Old Oct 23, 2006 | 03:11 PM
Superglue WRX's Avatar
Assuming you have a big enough turbo to flow enough air justify an 8K RPM limit, I'm not sure if the stock heads would support that amount of flow. Even then, that's putting over 1K RPMs on the entire engine including the bottom end. I don't think this is a situation where you can throw on some stiffer valve springs and be done with it.
You're probably better off getting the entire EJ207 engine and transmission for something like that. The engine and head modifications you would need to make on the EJ205 just don't seem like they would be worth it. Plus, the EJ207 comes with a valve timing system, an 8K RPM limit, forged internals, and other goodies that put our's to shame.
Good luck!
Old Oct 23, 2006 | 04:21 PM
WickedWRX's Avatar
well im tring to get the most out of the gt35R
Old Oct 23, 2006 | 05:08 PM
Turbo Lag much?
GT35R + EJ205 = dyno queen
I would highly recommend you consider a different turbo first. That set up is going to give you awful response all the way up to ~4500 RPM. Spool is going to be plane terrible. You can save yourself a lot of trouble with a 20G and meth or alky injection.
Have you done any kind of research on what set up you want? You seriously don't need a turbo that big. You would probably get slaughtered by other WRXs with smaller turbos because they will have a much more usable power band. Not to mention all of the stress that GT35R would put on your engine internals and drivetrain.
Peak horsepower numbers are for Camaro and Mustang fanboys... it's all about usable power dude!
Old Oct 23, 2006 | 05:31 PM
WickedWRX's Avatar
well i already have the 35r on my car. it makes full boost around 4500rpms and i love it. my setup seems to work great for the street.
Old Oct 23, 2006 | 06:09 PM
cbf246's Avatar
Car Info: 04 WRX
have you dont anything to the tranny or changed out the internals?
Old Oct 23, 2006 | 08:14 PM
meilers's Avatar
At 8000k you have to worry about so many things -- valve lash, injectors "going static," drying out the oil sump, heat shocking the pistons, etc. The amount of work it takes to move the RPM limit north is nothing less than a fully-built engine from cams to crank to pistons and block. When you consider that the power for turbos on the 2.0l block falls off like crazy past 6500 RPM, there is no reason to go further -- it won't make you any more power. You run into limits of the intake manifold, throttle body, intercooler and many other parts of the system that deliver air and fuel.
Old Oct 23, 2006 | 09:07 PM
I'm glad you like it, seriously. But have you tried other WRXs with 18G or 20G turbos? Boost comes on much sooner and still holds on strong after 6K. I really think you're missing out. Or maybe it's just me, I could never tolerate that much lag. When I step on the gas, I want power. I'm hardly ever at 4500 RPM on a normal day.
I dunno, I hope you're happy with your current set up then.
Old Oct 23, 2006 | 09:13 PM
BLUEJ20's Avatar
Car Info: 07 Car
Originally Posted by sigma pi
not for long
JDM sti yes
isn't devision spelled division correct me if im wrong
part of ur morrette mafia
Old Oct 23, 2006 | 11:01 PM
Jakes02's Avatar
Car Info: 2002 WRX
STI engine/transmission would be better for a gt35r. the EJ20 and EJ25 have oil issues when you bump the redline up. (like meilers said) built engine is about the only way to SAFELY increase your redline.
Old Oct 24, 2006 | 08:01 AM
Originally Posted by Superglue WRX
Turbo Lag much?
i agree
Old Oct 24, 2006 | 08:05 AM
WTLW
https://www.i-club.com/forums/showpo...postcount=5954
Old Oct 24, 2006 | 04:06 PM
WickedWRX's Avatar
right now i do alot of highway driving so i can use all the power. around town the turbo still works good before boost. the lag keeps me from getting tickets around town lol.
Flame30689
Sep 22, 2008 10:16 AM
2point5AWD
Jul 1, 2006 07:19 PM
Uniquedude
17
Mar 21, 2006 11:46 AM
ilivas
Jan 7, 2004 12:48 AM
