4eat transmission and bov question
Old Dec 27, 2003 | 06:10 PM
ScoobyBoy's Avatar
is the bov 100 atmospheric?
Old Dec 27, 2003 | 08:25 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
Originally posted by silver_rex_4eat
I know the 50/50 is better but i trust the subaru tuner shop i deal with and they said audis and the like have problems with 100% but they havent had ne problems running them on subaru wrx.
The 100% should be louder right than a recirculating?
100% should be very loud
Old Dec 27, 2003 | 09:37 PM
BoOm's Avatar
The bov sounds differ from different engine loads. My stock bypass valve is very loud when I'm driving or spooling while in motion but never sounds off when I'm out of gear.
Old Dec 28, 2003 | 02:19 AM
iNfEk's Avatar
Is there any 4eat owners witha bov that can help me. I just bought the turbo xs type h bov. It is rated for 10-25 psi. I am running an turbo xs axleback, k and n air filter and the silencer mod for now. i plan on getting a cobb tuning reflash stage 0 some time this winter.
my question is when i got the car in park and or nuetral and rev the engine the bov goes off and sound s awesome. The problem i am having is getting the same type of sound when the car is moving. I tried accelerating hard and letting off the gas and i can hear it b ut i sounds more like a fluttering noise and alot quieter than when in park. I think with a manual transmission it would be easier to get the sound. I am wondering if when i get the reflash and the boost is increased in the ecu will it help or should i have the tuner look at it. He told me it will flutter a bit when i was going home but will that go away as the bov works it self in? or is that the best it will do?
My feeling is if it sounds great in park it should blow off nicely when the car is boosting when driving. i heard sound clips of other bov on a website and you can clearly hear it. the way it sounds on the website is the way it sounds when i am parked but i cant get that same result when moving.
How do u other 4eat guys do it?
thanks
chris
well for me I notice that I get the fluttering noise when the car is still cold... but once it gets warmed up and the bov is warm them it's loud as hell!
Make sure that you don't have the screw tighted to much other wise it will take more boost to make it go off... The fluttering noise you hear is the bov piston going up and down so it is doing it's job it just might be that the pressure is not great enough to give it that sound you're looking for.
Also you don't want to loosen the bov to much since this will cause problems for you later.
Hope this helps some... Also for the 4EAT it's not really necessary... BoOm only has the stock bypass valve and his is VERY LOUD! For me it's just a toy! it's great for when you want to get a chicks attention
Jon
Old Jul 7, 2004 | 07:11 PM
RussB's Avatar
Car Info: $200,000 sports car
you drive an automatic. the throttle body doesn't between gears because you don't lift off the throttle, so the pressure in the IC probably doesn't get high enough for your BOV to make noises.
luktang
Mar 17, 2005 08:31 PM
russ
Oct 17, 2004 02:18 PM
iNfEk
Jan 12, 2004 11:55 PM
silver_rex_4eat
Dec 30, 2003 01:45 PM
iNfEk
Wanted
Dec 20, 2003 02:57 AM
