what do you think of this set up
Old Feb 24, 2003 | 06:31 PM
wannaberacing's Avatar
Car Info: 2002/2.5/sr40/400hp
turbo
I would get and s/r40 or s/r50
http://www.airpowersystems.com.au/wrx/aps_turbo.htm
More bang for the buck.
Old Feb 24, 2003 | 06:33 PM
front mount
Dude,
Have you seen this:
http://www.airpowersystems.com.au/wr...wrx_fmi_03.htm
NOW that's a front mount
Old Feb 27, 2003 | 11:37 AM
WREXXED's Avatar
Car Info: 2002 WRX
Sounds good but your also going to need some supporting mods. Custom uppipe, fuel pump, injectors, and some form of management.
You might want to check out www.quantum-racing.com. There coming out with some kits that might suit your needs.
Good Luck.
Old Mar 13, 2003 | 12:10 AM
boost
How long do you want your engine to last?
More boost
aggressive timing
leaner mix
these things can make your wrx fly.....straight to the rebuilder.
You'll have the baddest wrx on the planet for one or two days.
Your set up is great for drag racing. Is that what you want to do in your spare time?
300 hp to the wheels will keep up with z06's and M5's ....how fast do you want to go?
Old Mar 13, 2003 | 07:15 PM
psi
Well I'm sure there are 100 opinions on this.
Personally I run max boost of 17psi between 4 and 5500 rpm then down to 15 through 7000.
My car is not a dragster. But it's damn fast. and I have 49,000 miles on the engine. NP
Boost isn't the only variable.
air/fuel and timing can help or hurt yor engine just depends on who tunes it.
Old Mar 16, 2003 | 03:07 PM
20lbs psi
I don't drag race. I can't afford it. Pushing your car that hard is ok if you don't need it to go to work the next day. Run your wrx at 20lbs psi at Laguna seca and you wouldn't last two laps.
I really like to road race on a track. Thirty minutes of all out ***** to the wall, hard braking, dancing on the asphalt is way more fun than two or three runs of 10 to 12 seconds anyday.
I'm running stock internals, for now, there's only so much money to go around. With my next turbo (APS s/r40) and an APS front mount, I'll be able to pass zo6's. That is sick. In 2004, we're going to stroke it with Jun and then the Vipers beware.......
Dave
