Has anyone switched from Vishnu's Ekutek to their Xede?
Old Mar 18, 2003 | 09:37 AM
Juliano's Avatar
Car Info: 2002 WRX
Wondering about power, driveability, etc.
Old Mar 18, 2003 | 04:52 PM
johnw's Avatar
I've got an Ecutek AND a XEDE. However, I just got it installed so the XEDE is still zeroed out. I noticed that I'm running leaner that I probably should be. So, I'll be using the XEDE to fix that.
Also, the 91 octane is really bad and currently I'm testing the DeltaDash's ability to retard timing by 5 degree for bad gas. If this is able to prevent all the pinging I'm getting, then I'll probably reset it back to 0 and use the XEDE to retard timing in the areas where I'm having knock.
Personally, I think it is better to keep the Ecutek and use the XEDE to minor adjustments. On the otherhand, the cost is alot more...
Old Mar 18, 2003 | 08:11 PM
Juliano's Avatar
Car Info: 2002 WRX
Do you have any friends with a similarly modded WRX that has a stock ECU? The install is simple and under 15 minutes. You could install it on another car just to see the difference between the Ecutek and the Xede. I already have the Xede, but am curious.
Old Mar 18, 2003 | 08:27 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Curious of what? You have one why not find out for yourself?
Old Mar 19, 2003 | 01:26 PM
Juliano's Avatar
Car Info: 2002 WRX
I'm curious with regard to a comparison between how an Xede performs for a given stage versus how an Ecutek performs for that same stage.
ADIDAS
Oct 26, 2005 08:57 AM
DHISMEMBER
Sep 14, 2004 05:21 PM
GR8-WRX
Jun 13, 2004 01:19 PM
mjones
May 28, 2003 04:59 PM
