Engine runs on after ignition switched off (was: I need your help?)
Old Sep 11, 2004 | 10:37 AM
need4sti's Avatar
Car Info: sti
could be your ECU´s or ignition.why dont you take it to a shop?
Old Sep 11, 2004 | 08:22 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Does that aftermarket gear include a turbo timer? If so that is what is keeping your car running. The ECU is not capable of doing this on its own once the ignition has been turned off.
Old Sep 13, 2004 | 12:04 PM
t-wrexxx's Avatar
You say your car has aftermarket stuff on it.
The car running after you shut it off would be a turbo timer. Look for it.
The turbo gauge is not reading because the vacuum hose leading to it is either kinked, or it has been disconnected altogether. Follow the vacuum line from the gauge until you find the problem.
It seems that you should find the original owner of the car and have him give you a once over of everything that has been modified, so you know.
Old Sep 14, 2004 | 05:21 PM
stevedood's Avatar
Car Info: _
check the wastgate actuator under the turbo heatshield - it could have popped off
i<3dirt
Oct 20, 2014 10:26 AM
harley29906
Mar 2, 2007 03:37 PM
n00bR
16
Feb 14, 2006 10:14 AM
ADIDAS
Oct 26, 2005 08:57 AM
