Ecu pulling timing!
Old Jun 26, 2006 | 11:25 PM
WrbImprezaSti's Avatar
Car Info: WRX
Ecu pulling timing!
why is my ecu pulling timing? its doing it alot lately. I disconnect the battery and it goes back to normal. Then shortly later its doing it again. I wonder if it has to do anything with my Ecutek tune.
Old Jun 26, 2006 | 11:34 PM
AdamBOMB_STi's Avatar
Car Info: 04.7 AW Time Attack STi
possibly the hot temperatures its been as of lately. the intake air temperature sensor is in combination with the maf. and if the maf heats up the IAT gets screwed up and likes to pull timing if the temps get too hot. I'd say one of the biggest flaws subaru did with the maf design because the "true" IAT's would be at the throttle body.
Old Jun 27, 2006 | 07:34 AM
mattsn0w's Avatar
try changing gas stations. This could be it but I would agree that it is probably heat related.
Also try putting in some 100 octane, that cures timing.
Old Jun 27, 2006 | 04:27 PM
true true, maybe the gas has been bad at the past gas stations.....
Old Jun 27, 2006 | 04:42 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
How do you know it is pulling timing?
Old Jun 27, 2006 | 05:32 PM
STINGR's Avatar
Summer + heat = sucks for our cars!!!! Are you data logging your car? How's your boost, and is it hitting target boost levels? Any negative knock corrections? Are you running your car with the ac on? If so, it will feel like it's running on 3 cylinders except for them v8's and up cruising around on full blast. Mine also feels like a dog with a tmic.
Ron
Old Jun 27, 2006 | 06:08 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
if the ecu picks up knock it pulls timing
crappy CA gas plus some record heat days your gonna loose performance
Old Jun 27, 2006 | 09:18 PM
subie OCD's Avatar
Car Info: 04 STi
Who tuned it?
Old Jun 28, 2006 | 08:45 AM
mine is pulling timing also. I have a link
just let it pull it.
its the nature of the beast
mr. m
Sep 2, 2003 11:43 AM
mysubaruimp
May 12, 2003 04:29 AM
mmboost
Feb 1, 2003 09:29 PM
