checking timing belts without pulling crank pulley
Car Info: 2001 sub. imp.
is there any way to check the timing belts on a 2.2L without removing the timing belt covers? it would be a pain to do that. and what mileage should timing belts be checked/replaced?
so you can take them off without removing the crank pulley? i didnt look too hard when i changed out my pulley but i remember thinking to myself, "man this is a lot of work to just check timing belts if i have to take off the crank pulley, maybe katie can wait a ffew more thousand miles till i check her belts"
yes, the crank pulley sits in the middle cover, there are two more covers that sit on the left and the right sides, just in front of the cam shafts. you can tell which ones they are because they have circles on them that line up with the cam pulleys and where they meet with the middle cover it looks like brackets almost. I know this because I recently had to change the seals in the oil pump.... big pain in the butt it runs off the crank shaft and to get to it requires removing most of the pulleys and the timing belt underneath the cover. If you need to change the belt.... I highly recomend doing thorough reading on the subject in a haynes or chiltons manual..... if it is done wrong it can cause serious and very expensive problems, by the way, chiltons recommends 60,000 the subaru dealer that i got my parts from recomended at least at 100,000. hope this helps, best of luck.
60,000 and 100,000 for the belt i mean, I wasnt clear. I purchased my car at around 40,000 on it, I now have 80,000.... Im not quite sure if it was changed by the dealer I purchased it from, but when I had it apart, the belt looked great so I didnt bother to change it, I will prob. do it at 100,00 in another year or so.
got ya, chiltons haynes etc dont make manuals for the impreza line so i think ill just check if they need replacing and if so, off to the ****** dealer it goes
CCC
Engine and Drivetrain
Feb 2, 2012 10:09 AM
demonbugeye
Hawaii Classifieds
May 4, 2009 03:26 AM
dyndragon
Feb 2, 2006 04:50 PM
Mat - 98 R/T
Feb 7, 2005 07:10 PM
