Damaged Injector ???
Old May 11, 2004 | 01:10 AM
Maniac's Avatar
Car Info: Silver 2002 WRX Sedan
Unhappy Damaged Injector ???
I bought some used STI injectors on eBay. One of the injectors looks a bit "banged-up" from installation/removal and handling. I am wondering if the damage is superficial or if it is going to cause any performance problems. Please see attached image of the actual injectors.
Your expertise and opinion are greatly appreciated!
Thanks in advance! (Arigato gazai mashu-ta!)
Maniac.
Old May 11, 2004 | 07:21 AM
areg's Avatar
Car Info: 04 STi/67 rotary 311/C20/DT Barracuda
As long as the holes are not tweaked you should be ok might want to send them to RC engineering to have the injector flow tested and then see if the seller will flip the bill...
Good luck.
Areg
Old May 11, 2004 | 08:16 AM
go go go's Avatar
Car Info: GF8 ver6
check the o-rings too, ideally change it to new one.
Old May 11, 2004 | 08:56 AM
Maniac's Avatar
Thanks for advice! How do I contact RC Engineering?
Old May 11, 2004 | 12:22 PM
areg's Avatar
http://www.rceng.com/
Old May 11, 2004 | 06:34 PM
Maniac's Avatar
Thanks!
gbmotorsports
May 13, 2003 01:22 PM
Speed Element
Mar 19, 2003 07:19 AM
HS WRB-rex
Mar 18, 2003 04:20 PM
Astacun1
Mar 5, 2003 06:21 PM
evilwrx
33
Nov 26, 2002 10:58 PM
