Which is better, Xede or Cobb AP stage 2 for the STI?
Old Mar 30, 2005 | 02:52 PM
xicema17x's Avatar
Car Info: 71 rb26 240z
Someone is offering me an used Xede for my STI for 400, although i was trying to compart between whether to get AP stage 2 or xede. All i know is that the used Xede is 400 and AP is 645. I know the price for xede sounds good, but is the power gains better that the AP stage 2? Need input asap.
thanks,
jason
Old Apr 24, 2005 | 09:29 PM
mnavarro's Avatar
I had an xede, there's only one guy to tune it and that's Shiv at Vishnu. I would go for something that everybody can tune, and that's either a ecutek or a utec. AP is pretty good too. If you just want to set it and forget it get the ecutek, contact gruppe-s, they're a great vendor and they're pretty close to you.
Old Apr 25, 2005 | 03:53 PM
inveSTigator's Avatar
Car Info: 05 Shivnuized STi (SOLD!)
If I lived where you did, I would just drive to Vishnu to get a tune. Anyway, Shiv flew down to TX and I had him tune my ride on the dyno w/ the V-370 flash (ecutek). I was extremely happy with the results. 05 STi btw. Most people around here use the AP for convenience.
Old Apr 25, 2005 | 06:27 PM
subabu05's Avatar
Car Info: 05 WRX Wagon
ap
I have an 05 rex and I'm running an AP with Cali map stage 2. From the sheer convienence factor I say go accessport. You should be able to pick up a used ap on the boards in the 450 range if you're a little patient. I like the ap because it's very easy to switch between maps, uninstall if I need to take my ride to the dealer for some reason, and reinstall so they have no idea I was running fuel maps. I'm still putting down good power with my set up (around 300) It's about what you want though. If you don't mind getting your car tuned each time you change/upgrade parts , and to squeek every bit of hp out of your car nothing beats custom tuning. Good luck with your decision.
Old Apr 25, 2005 | 06:58 PM
kewldan's Avatar
From: Houston, Texas "Drive it like you stole it.." 13.034 @ 105.19 mph
Car Info: Aspen White 04 STI, Silver 03 RS (wife's car)
I have an 04 STI with Stage 2 COBB AP and I noticed a big difference just going from stage 2 91oct to stage 2 93 oct. I am boosting around 23psi which can be considered bad I guess for the stock turbo and I started spiking so I am going to try the LWG map to see what difference the boost is.
Old Apr 25, 2005 | 10:54 PM
DomozitoLK's Avatar
You can tune the XEDE...that's the whole point of having it over a reflash. If you have the XEDE module, you can download the tools from XEDE direct or from Vishnu:
http://www.xede.com.au/software.php
http://www.vishnutuning.com/xede_support_wrx.htm
"XMAP Full-Functional Tuning Software (.zip file)
Allows user to create new, or modify existing, XEDE tuning maps. Only recommended for those who want to tune and understand the consequences of improper engine management calibration."
srbaugust
15
Jun 2, 2013 02:02 AM
mlane1
15
Feb 21, 2004 04:47 PM
s-y
Jan 8, 2004 04:56 AM
STi City
Nov 1, 2003 03:36 PM
