ATTN: CobbTuning
Old Jul 5, 2005 | 09:56 PM
RAGEWRX's Avatar
Car Info: '04 JBP STi
ATTN: CobbTuning
You're realtime and basemaps for the '04 STi AccessPORT are incorrect. The Stage 2 93oct basemap is the same as the Stage 2 93oct HWG realtime map. They both do not work. I tried loading it as a realtime map. It still displays my 91 oct map in the current map selection. What's the deal???
Old Jul 6, 2005 | 12:57 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I do not beleive COBB guys read this forum, but sure, why not try to get their attention here.
Old Jul 6, 2005 | 09:10 AM
FLIWRX's Avatar
Former Sponsor
Car Info: 2002 WRX
Hi RageWRX
On the Access Port when you check and see what map you are on it only displays your current base map not your current real time map. If you have any questions send me a pm and we can try and work something out.
Ryan
Fine Line Imports
Old Jul 17, 2005 | 08:40 AM
REXRED04's Avatar
if you read in the instruction manual the ap only displays the base map that you are running (it does not display your real time map). to put the stage 2 map on you need to reconnect the green connectors and hook up your small adapter under the dash. after than select stage two 93 and reflash your ecu. once that is done go in and update the real time map with the map of choice. also be advised after the flash it will take some time to relearn your driving charictaristics (couple hundred miles).....
Last edited by REXRED04; Jul 17, 2005 at 08:43 AM. Reason: update ecu relearn info
Stryder1808
Hawaii Classifieds
Apr 19, 2010 03:28 PM
99rsblu
Jul 7, 2006 02:36 PM
Mosh
Feb 2, 2004 09:41 AM
2manycarz
Forester General
Oct 24, 2003 03:20 PM
greydune
45
Apr 25, 2003 06:58 PM
