AP boost levels?
Car Info: o5 esteaeye
AP boost levels?
Im running a cobb tbe right now and I am considering an accessport with protune. I was just wondering what the maximum boost i could see out of that setup with stock turbo.
Would a boost controler after the ap be benificial?
Would (say 18 to 20 lbs) require new pump and injectors?
Would 18 to 20 lbs be safe?
thanks...
thanks...
Originally Posted by dyepball1
Im running a cobb tbe right now and I am considering an accessport with protune. I was just wondering what the maximum boost i could see out of that setup with stock turbo....
Would a boost controler after the ap be benificial?...
Would (say 18 to 20 lbs) require new pump and injectors?...
From: My lugnuts require more torque then your Honda makes
Car Info: 05 WRX
Originally Posted by VIBEELEVEN
I hit 1.1x bar with the stg.2 cali map. Whatever that is in psi.
spdkills
Dec 26, 2002 07:33 PM
