AP boost levels?
Old Jun 6, 2006 | 10:39 PM
dyepball1's Avatar
Car Info: o5 esteaeye
AP boost levels?
Im running a cobb tbe right now and I am considering an accessport with protune. I was just wondering what the maximum boost i could see out of that setup with stock turbo.
Would a boost controler after the ap be benificial?
Would (say 18 to 20 lbs) require new pump and injectors?
Would 18 to 20 lbs be safe?
thanks...
Old Jun 11, 2006 | 01:16 PM
dyepball1's Avatar
anyones .02 is apreciated
Old Jun 14, 2006 | 11:24 AM
okpanic's Avatar
Car Info: 07 Silver Mazdaspeed 3
the basic cal stage 2 map runs at 17.5 psi. I think ( don't know for sure ) that 18 psi from a protune should be safe.
Old Jun 14, 2006 | 11:32 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Originally Posted by dyepball1
Im running a cobb tbe right now and I am considering an accessport with protune. I was just wondering what the maximum boost i could see out of that setup with stock turbo....
I think the TD04 loses effeciency about 16-17psi.
Would a boost controler after the ap be benificial?...
No.
Would (say 18 to 20 lbs) require new pump and injectors?...
Probably, I would not run over 17psi on the stock turbo or stock engine for that matter.
Maybe for a little while, but not likely.
Old Jun 14, 2006 | 08:18 PM
gqchynaboy's Avatar
From: My lugnuts require more torque then your Honda makes
Car Info: 05 WRX
I see that I hit 17psi on my Stage2 Protune with 91 Octane
Old Jun 14, 2006 | 08:53 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
I hit 1.1x bar with the stg.2 cali map. Whatever that is in psi.
Old Jun 14, 2006 | 08:59 PM
tmeultraman's Avatar
not to highjack but what would that be measured as in hkpa?
Old Jun 14, 2006 | 09:10 PM
gqchynaboy's Avatar
Car Info: 05 WRX
You happen to know your whp and wtq for your Stage 2?
Old Jun 14, 2006 | 09:59 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Not yet.
02silversuby
Jun 21, 2004 11:40 PM
wonton2049
Apr 1, 2004 04:50 PM
Slamsitin
17
Sep 20, 2003 12:32 AM
turborambler
May 30, 2003 08:07 PM
spdkills
Dec 26, 2002 07:33 PM
