Is 19 PSI too much?
Old Jul 5, 2004 | 07:12 AM
Wingless Wonder's Avatar
Origami posted by lost
How much boost can this thing safely handle? The engine number is EJ20GDW4PJ. I am guessing that the turbo is not stock. I can't tell what brand the turbo is.
That's a tough question to answer even if we do know which turbo you have because we have no way of knowing how the car was tuned (both boost and ignition advance maps). What are you using for engine management?
Does the previous owner have any records or information he can share with you?
Do acelerometers work? Anyone know a good brand if they do work? I really want to get a good estimate of the horse power, I can't find an AWD dyno here.
They work but the consumer models they sell for road use (BEL, g-tech, APEX'i, etc.) should not be used to compare numbers with real dynamometers or with different models of accelerometers. They'll give you ballpark figures and graphs but really should be used to chart relative changes when mods are made or test conditions change (weather, altitude, traction, etc.).
Old Jul 5, 2004 | 02:15 PM
funkdrmr's Avatar
Car Info: 2002 WRX Sedan - Silver
Sounds like you might have some pretty nice mods already done. Don't let the dealer touch your car!!!! Find someone local, and have them check it out!
Old Jul 7, 2004 | 09:53 AM
mmboost's Avatar
tangent:
heh yeah... except I didnt laugh too hard in my case. I stupidly assumed at night that a wide puddle over a day after rains was by that time just a shallow one. The lip ended up holding the weight of the front passenger corner.... and not to well I might add. Fortunately I had wireties in the trunk.
jason
Old Jul 12, 2004 | 04:49 PM
Kay95's Avatar
ej20g is the closed deck if i remember
the turbo if it is stock is a vf 22 or vf23 and the intercooler is i think the largest put in any sti so yes the motor should be fine
it sounds like the dealer knows that you have limited knowledge of your car and wants to take advanage of you for it
the power the car is making now is most likely more than 300 if the boost was increased
as far as gearing if you have a RA sti the gears will be very low and even regular sti's have lower than normals gears compared to other cars
Old Jul 12, 2004 | 06:39 PM
RoadSpike's Avatar
missread post (deleting)
Old Jul 13, 2004 | 09:38 AM
UK n00b's Avatar
Car Info: the blue bucket
Yep the EJ20G between 94-98 are closed deck, It is more than likely running the vf23 and can more than handle 19psi as long as it's not been thrashed for all of it's previous life.
Old Jul 13, 2004 | 07:39 PM
Kay95's Avatar
are you sure about the 94 to 98 because i thought that they where made from 93 to 96 and then semi closed after that
Old Jul 14, 2004 | 10:14 AM
UK n00b's Avatar
Nope not too sure other than the 98 EJ20G I have in peices here at the shop.
Old Jul 19, 2004 | 10:28 PM
Uncle Scotty's Avatar
Make sure to put the highest octane gas in it you can get!!!!
Don't let the dealer **** wit it.
Find someone you can trust who knows cars and go over it and make sure all the 'wear items'(brakes and such) are good to go.
Change the oil and filter.....gas it up, and go play
Old Jul 20, 2004 | 12:23 AM
SsTiNgEr77's Avatar
Car Info: 2002
damn... another marine stuck in okinawa :\
beats iraq though
if i were u.. i would run 17-18 psi with that car because you dont want anything bad 2 happen...and make sure u put the highest octane gas into it
skimobile
Jul 28, 2005 07:14 PM
Dodiox
Feb 4, 2005 01:17 AM
rollinDAwrx
Dec 3, 2004 12:50 PM
antdiesel3
Nov 8, 2004 02:56 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
