Uh oh...reverse gear engaged while moving forward.
Old Apr 26, 2004 | 11:39 AM
nic3krnnamja83's Avatar
well i think as long as no grindirinidnrindin noise was made to really scare u i think it is ok. I used to drive a auto civic and i used to do crazy things all the time. i think you would have known if somehting was wrong
Old Apr 26, 2004 | 12:05 PM
my2003wrx's Avatar
If it drives ok, I wouldn't worry about it. My friend used to always change gears while parking, provided that it's not 15mph, but you get the point.. He never waited for the car to stop and nothing negative happened to his transmission. Unless strange things start happening, you probably don't have to worry about it.
:banana:
Old Apr 26, 2004 | 12:11 PM
Gleb83's Avatar
Car Info: 2002 Alpine White WRX
When I had my maxima I put it in reverse driving at around 35 mph. What happened was my car shut off, no grinding. I put it in neutral without stopping started it and it ran fine. I would think that if a 1990 Maxima had a safety mechanism then a 2002/2003 Subaru would have something also. Since it went into reverse with no grinding/weird noise it should be ok.
Old Apr 26, 2004 | 06:58 PM
subawho?'s Avatar
Car Info: 2002 MBP saloon
For everyone's FYI:
If you don't want your car to "click" be NICE and tip your valet
Old Apr 26, 2004 | 07:03 PM
my2003wrx's Avatar
Originally posted by subawho?
For everyone's FYI:
Or they'll go Ferris Bueller on you.
:banana:
Old Apr 26, 2004 | 08:11 PM
subawho?'s Avatar
^^^^^ only if they're REALLY BIG jerks.
SVXdc
Oct 31, 2009 01:16 PM
ScoobyWho?
May 20, 2009 02:56 PM
c4ninja
Jan 8, 2006 10:14 PM
ryball
Feb 22, 2005 05:45 PM
