Ticking sound with reverse gear
Old Apr 28, 2007 | 03:36 PM
dankrouse's Avatar
Car Info: '04 WRX Wagon
I just developed the same problem recently, it ticks in reverse with or without the clutch depressed. It ticks while rolling unless i take it out of gear. i don't know if the transmission is covered in the 60,000 mile powertrain warranty, i hope so. I'm going to have a dealership look at it.
Old Apr 28, 2007 | 03:43 PM
dankrouse's Avatar
Any word from the dealership on what part broke? I have the same problem.
Old Apr 28, 2007 | 04:35 PM
cbf246's Avatar
Car Info: 04 WRX
sounds like it might be going out. it might be due to metal shavings thats messing with the reverse gear? have you check the fluid for metal shavings? normally when you have a lot or a good amount of shavings in the tranny, its time for a rebuild.
Old Apr 28, 2007 | 04:41 PM
cbf246's Avatar
Car Info: 04 WRX
hahaha. this is a pretty old thread. sounds like the reverse gear went out. as stated, there is no syncro for reverse since it is a straight cut gear and will not pop out of reverse.
STi_rebirth
Jun 6, 2006 10:40 AM
1 fststi
May 6, 2006 04:13 PM
lastlaugh
Dec 15, 2005 12:47 AM
jrgman
Nov 27, 2003 06:22 PM
scootr
Nov 24, 2002 11:39 PM
