Speed Sensor Not Working And Won't Rev Past 5K in Every Gear
Old Aug 6, 2010 | 03:56 PM
BlueBullet's Avatar
Car Info: 2002 Subaru WRX Wagon World Rally Blue
Unhappy Speed Sensor Not Working And Won't Rev Past 5K in Every Gear
I have an 02 wrx wagon and the speedometer stopped working along with the engine not able to get past 5000rpm's in any gear, it just starts stalling, and the miles don't register anymore on my digital gauge. I had a transmission shop swap the speedo gear from my original 02wrx trans into an 05LGT 5spd trans, since the leagacy's speedo was run from the wheel sensor instead of the transmission. I have ruled the following things out so far: I have checked all my fuses, the wiring connections from the sensor to the group of wires that goes into the main group of wires running through my firewall, the sensor itself(I replaced it 100 bucks I'll never get back), unplugging the battery overnight, and resetting my mapping software, hell I even tried banging on it with a wrench to see if that would do anything! Any opinions and help from some well knowledgable Scooby owners is much appreciated! I am wondering if I could put the sensor in the same place as the LGT (on the wheels?), or maybe there is an electrical connection problem between the transmission wires and the ECU, or TCU? Or if anybody would recomend a good mechanic who wouldn't be interested in how deep my pockets are.
Old Aug 6, 2010 | 06:32 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
The speed sensor gear...the one that's driven by 3rd/4th gear cluster...is probably sitting at the bottom of the transmission.
Have the shop that did the swap look at it for you.
Old Aug 7, 2010 | 09:16 AM
BlueBullet's Avatar
I would gladly take it back to the shop if I was still in Texas I am going to do what the Brucelee man suggested and just take my scoob into GST Motorsports shop and have them take a look at it and see what they recommend. I can only warn others that a transmission shop run in the state of Texas should not be trusted, and probably any other shop that does not have specialty knowledge of imports and specifically Subarus, since they are 'touchy' at times. I have learned my lesson though, and also that only quality parts are going into my car as well from here on out. I say do your resaerch because the best deal isn't always what you should look for...
tayna1
Jan 1, 2007 12:36 AM
2point5AWD
Sep 6, 2006 09:38 AM
SilverRex04
29
Dec 13, 2004 10:40 PM
SilverRex04
20
Nov 23, 2004 05:50 PM
slammin
Dec 25, 2003 11:28 PM
Top
