engine wont rev past 4500 rpm
Old Dec 19, 2003 | 08:09 AM
Egan's Avatar
Any CEL's? Sounds almost like limp mode.
That being said, the fuel pump should make no difference. The fuel regulator will control how much pressure gets through and the injectors will control how much flow gets through. Did you put the stock injectors back on or are you running something larger?
If all you have is the pump and an uppipe, the stock ECU should have no problem adjusting. Did you reset the ECU after you pulled everything off?
Old Dec 20, 2003 | 01:02 PM
Egan's Avatar
You need to pull the code. Don't just assume it's the constant CEL from your exhaust. There may be something else going on.
Old Dec 20, 2003 | 01:33 PM
If you have the stock exhaust on, you shouldn't be throwing a CEL except for the EGT sensor, which can be taken care of with a resistor. However, you do need to be certain what the CEL(s) are.
Old Dec 25, 2003 | 09:36 AM
Pi7467mp's Avatar
Car Info: 2000 2.5 RS USDM STI block, SOHC heads GT25 Ball bearing turbo, TMIC, TXS BOV, Tial wastgate, etc...
Hey man I had the same problem, but I don't know if this is what is going on in your situation.. I would floor my car and under boost I would get this sputtering exhaust note around 4500 RPM... and I thought it was in limp... but My car was running way too rich.. according to suby sources... if you are running way too rich under boost in High rpms, your primary O2 sensor is overwhelmed and makes you car not able to run past 4500 RPMs unless you go that route under partial throttle.. hope that helps.
Old Dec 25, 2003 | 11:28 PM
Egan's Avatar
Which is exactly why I asked him if he still had the larger injectors in his car. I know for a fact the ECU will cause the car to buck with the STi injectors. Way too much fuel.
Flame30689
Sep 22, 2008 10:16 AM
tayna1
Jan 1, 2007 12:36 AM
SilverRex04
29
Dec 13, 2004 10:40 PM
carletto
16
Dec 5, 2004 10:07 AM
SilverRex04
20
Nov 23, 2004 05:50 PM
