Cruise Control not working on MY00 2.5RS... tried a few things and still not working
Car Info: '08 FXT Dark Gray Metallic
Hi,
I've been searching through forums trying to find out why my cruise control doesn't work. The button with the light that activates cruise control lights up, but when I use the stick connected to the steering wheel to set the speed, nothing happens. I've tried a few things so far to no avail:
- Honked the horn: I read that there is a relay that connects the horn and the cruise control so if the horn doesn't work, then that could be the culprit.. however, the horn works
- Checked the fuse and it looks good: I'd be worried because the fuse for the cruise control is also responsible for the ABS ... eek
- Disconnected the battery for a few minutes, pumped the breaks, and put it back on: I read that sometimes the ECU will stop the cruise control from working because of some problem, and resetting it should make it work: didn't work
- I also read that there is a vacuum connection that needs to stay sealed to give pressure to the cruise control... I didn't know what I was looking for so I didn't find it: all hoses I saw were still connected
- Last but not least, I checked under the clutch pedal to see if a "little white plastic disk was still there." I read that this is a sensor that turns cruise control off if the clutch is depressed. Some people reported that theirs fell/broke off and it stopped working. I think I found it but I didn't have a picture to go off of. I found a white disk that hits a button connected to another piece. The other piece was hitting the white disk, causing it to go into itself... so I think that means it's still working
I'm open for any and all suggestions.
Thanks-
~Eric
Thanks-
~Eric
Same thing
Just posted this on another thread. My 2K OBS had exactly the same problem, dealer in WV replaced a bushing in the clutch pedal and it stayed fixed for a year. Going back in a few weeks.
Thanks so much for replying. I was thinking of hooking up with a friend who has the same car and swap the cruise control stick from the steering wheel or the actual cruise control part that is under the hood-pop button... but I haven't done that yet.
What bushing did they replace and how did that make the cruise control stop worknig? If you know...
Correction:
Receipt says, "Bearing" not bushing. No part number though. Called them and they had an e-copy but still waiting to do this after my move, soob dealer here essentially wants a blank check for "diagnosis". Perhaps someone has a pdf diagram of the clutch pedal assembly. Saw a site with a complete tech book recently but lost it. I can't imagine there being more than one or two bearings in the whole clutch pedal.
I fixed the problem. The hose that goes to the cruise control servo behind the airbox came out. People on another board helped me to figure it out.
Cathy000
Sep 7, 2006 06:25 AM
DreddRS25
Subaru OEM Parts For Sale
Feb 8, 2006 12:32 PM
sfwrx2
Aug 10, 2004 10:01 PM
