OK, the flip side. Who has NOT had any gearbox problems?
Old Aug 22, 2003 | 06:46 PM
  #31
rhk118's Avatar
Car Info: '03 Black Sedan
12,500 miles...stock...no clutch/tranny problems, just crazy female drivers crashing into me...
Old Nov 10, 2003 | 08:05 PM
  #36
platypus's Avatar
Car Info: dangerous with a wrench
I didn't have any issues with my stock gears through 20-some odd thousand miles of highway, rallycross, and rally driving.
Now I have a hardened RA gearset, and I don't ever expect to have problems again. :banana:
Old Nov 12, 2003 | 08:55 AM
  #37
The Mirror's Avatar
Did you get beefier synchros with that RA gearset?
Old Nov 12, 2003 | 12:12 PM
  #39
platypus's Avatar
Originally posted by Silver arrow
How are the ratios,
The ratios are much more evenly spaced than the stock WRX gearbox. First is taller, and then everything else is shorter.
do you have to shift to third to reach 60 mph?
Mmm, not sure off the top of my head. I could probably get 60 still in 2nd, but I usually shift well before redline.
Did you have to change diffs?
Most folks that would do this sort of a swap will put in new diffs. I didn't, so no, you don't *have* to.
How much did it cost you and who did the work for you?
MPJ Performance did the work for me. They do this swap for $2600.
Old Nov 13, 2003 | 01:05 PM
  #40
The Mirror's Avatar
How much was freeway mileage affected?
Old Nov 13, 2003 | 05:18 PM
  #41
international B's Avatar
Chewwwwy
i had 77k very hard miles on my 5mt when i removed it, no problems at all. 6spd is way better tho.
Old Nov 13, 2003 | 06:29 PM
  #42
mrruins's Avatar
Car Info: 05 toyota tacoma
driving style: double clutch & rev match EVERY down shift???
whats that?
Old Nov 16, 2003 | 07:50 PM
  #43
mrruins's Avatar
so what is the definition of the following driving style?
Gombessa
Sep 11, 2009 07:59 AM
grex767
May 27, 2006 10:37 AM
garziniwrx
Apr 22, 2003 06:38 PM
pook
Mar 22, 2003 03:02 AM
stealth-wrx
Jan 20, 2003 05:10 PM
