OK, the flip side. Who has NOT had any gearbox problems?
Old Jun 19, 2003 | 07:30 PM
Captain Ned's Avatar
Car Info: '02 WRX Wagon
51K miles on my '02 WRX wagon and I can still d/s into 1st at 20mph. Clutch shudder from Day 1 for the first 5 minutes, never again after the first 5. No mods, but enthusiastic driving & lots of dirt roads.
The Captain
Old Jun 21, 2003 | 12:23 AM
John #555's Avatar
Car Info: 02 WRX
almost 61k mi. since Sep '01. All stock, and i like to keep it spinning bet. 3-5k rpm all the time. Clutch was replaced under warrenty at 35k, although, i was really complaining about the tranny noise. the shudder showed up again but not that bad (or I got really good at avoiding it!) tranny makes loose metal noise in neutral at idle but the dealer convinced me that in 'older' tranny main shaft makes that noise... ?
Old Jun 21, 2003 | 07:23 PM
Does it make the noise in gear or in neutral? If it makes more noise in neutral you need input shaft bearings promptly.
Old Jun 24, 2003 | 10:13 PM
John #555's Avatar
Car Info: 02 WRX
it happens in neutral ! I did mention the input shaft bearing (or 'main' shaft as they called it) but they quickly pointed to other older WRX's in the lot (~40k mi.) making the same noise. I couldnt convince them otherwise at that point...
can you think of any way to get their attention?
Old Jun 25, 2003 | 12:39 AM
Ok, so you are idling, clutch in, and you hearing the ringing sound, right? And when you let the clutch out, it goes away (almost entirely)? If so, you need bearings. I don't know why they are saying you don't. Gotta go to SOA I guess.
Old Jun 26, 2003 | 12:38 AM
John #555's Avatar
Car Info: 02 WRX
sorry, i'll try to be clearer... after the car's fully warmed up, idling at a stop, when i let out the clutch in neutral I hear this metal rattling kinda noise (sounds almost like old MB diesel idling). As soon as I push in the clutch the noise goes away. everytime I let out the clutch in neutral i hear the same noise. Is it just input shaft spinning, or is it somethng else?
Old Aug 13, 2003 | 10:20 PM
WyldKardzWRX's Avatar
Car Info: 2002 Aspen White Wrx Wagon
no problem so far on second tranny. lol
Old Aug 19, 2003 | 05:52 PM
jrushlow's Avatar
59K no mods. I have had no trouble with it... I am not a typical WRX driver though I baby it
Old Aug 19, 2003 | 11:52 PM
The Mirror's Avatar
Okay, I started this thread, so now I'll chime in. No problems in 4000 miles on my 2003. No clutch drops, and just a Prodrive axle back. Reverse is easy to get into with a little trick, and 1st is reasonably selectable.......for a Subaru.
Not good enough for me though. I hate the ratios. As soon as I can get it from rallispec, its a STi RA gearset.
-Mirror
Old Aug 20, 2003 | 02:51 PM
Try getting a used RS gearset first. Won't cost you much, and the ratios are very similar. You will definitely notice a huge difference from the WRX ratios though.
Old Aug 20, 2003 | 05:48 PM
The Mirror's Avatar
I actually did consider that, but at the end of the day, used Subaru transmission parts make me very nervous. I figure I'll absorb the extra expense for new, cryo treated stuff.
Old Aug 22, 2003 | 08:36 AM
fstbluewrx's Avatar
Car Info: 2010 LANCER GTS
trans
i hope this helps! i have 45,000 miles on my baby with many mods and have had absolutley no problems what so ever with the trans or car. I do race also, just no dumping of the clutch i just slip it.
my mods are-
vf22
tt supra fuel pump
borla header
pde upipe
pde down pipe
greddy catback
injen intake
txs mbc at 16.5psi
intercooler hoses
also i have aps fmic, sti injectors, fuel rails waiting to go in. im waiting to get utec before install the rest
