Notchy shifting w/OEM short shifter, need bushings?
Old Sep 18, 2003 | 12:52 PM
Blue_Rexer's Avatar
Car Info: 03 Blue WRX
Question Notchy shifting w/OEM short shifter, need bushings?
I have an 03 WRX with the OEM short shifter in it. Shifting is a lot notchier than I would like it to be throughout all gears. Also on cold startup it has a big problem going into reverse!!
Will those Kartboy shifter bushings fix this problem or is this a tranny problem that I should take up with Subaru??
Old Sep 18, 2003 | 01:23 PM
04blkWRX's Avatar
Car Info: Black WRX, stock
I have a similar problem, but primarily going into 2nd. Suggestions?
Old Sep 18, 2003 | 01:51 PM
MOG_22's Avatar
the car comes with a notchy shifter, you can try changing to synthetic tranny oil and see if that works. I don't think there is anything the dealer can do for you.
Old Sep 18, 2003 | 02:28 PM
acsWRX's Avatar
Car Info: 2003 WR Blue WRX Sedan
I've heard of dealers admitting to the difficulty getting the car into reverse, and sometimes i need to let the car warm up a little bit before trying reverse. Synth tranny oil may help a lot...
Old Sep 18, 2003 | 08:19 PM
Blue_Rexer's Avatar
So there is no real way to get rid of the notchy shifting completely, even though I will change to synthetic tranny oil, I was hoping that was what those bushings did?
Old Sep 28, 2003 | 05:24 PM
ZAGWRX's Avatar
Car Info: 2006 Sti
Angry same problem here
I too have the factory short shifter and it is hard getting it into reverse off a cold start. One thing that helps is, putting the car into first and nudging forward a little bit, then trying to put it in reverse.
This seems to help me sometimes, but it would be nice to solve the problem for good.
Indirecked
Jun 23, 2009 10:32 AM
mothman331
Mar 21, 2007 08:12 PM
blue blurr
Jun 22, 2006 02:53 PM
ucbsti
Jul 19, 2005 06:44 PM
HoneyRex
Apr 6, 2005 01:42 AM
