Need Some Help i-Clubbers!~ (Transmission Fluid)
Old Sep 25, 2009 | 11:43 PM
hey1230000's Avatar
Car Info: 2004 Subaru WRX
Exclamation Need Some Help i-Clubbers!~ (Transmission Fluid)
Hello guys, today for the first time, I changed the transmission fluid and the differential fluid besides doin oil changes and changing worn head/fog lights.. Anyways here is the issue. You guys know how that hole to fill the transmission is really hard to reach without removing the intercooler?? ( I managed to MacGuyver a hose attachment to a funnel and worked my way around after 10 minutes of frustration and beer ) I accidently leaked some tranny fluid, and when I went for a test drive to see if theres any leaks , I noticed it starteed smoking around the downpipe area near the tranny filler hole thingy.. Anyways I was wondering if this is a big issue such as damage to parts and wiring etc, or can i just clean this up some how?? im working on this in my garage right now, looked nasioc looked scoobymods and couldnt get a quick answer.. Any imput on this would be greatly appreciated.. Thanks!!
Old Sep 26, 2009 | 09:14 AM
jam007's Avatar
Spray it off with the water hose......Just cover all intake areas, or itll eventually burn off.
Old Jan 27, 2010 | 11:16 AM
ayoraider07's Avatar
Car Info: 04 wrx
don't spray water onto the turbo, especially if u dont have the heatshield on it, you'll crack ur turbo if it's hot and water hits it..
JMeltzer4
Aug 17, 2010 07:23 PM
hey1230000
Sep 26, 2009 12:30 AM
jinorazi
May 22, 2008 04:52 PM
jasno999
Feb 9, 2004 04:49 PM
addictarmy
Sep 24, 2003 11:47 AM
