Need help with noise from transmission area
Old Oct 18, 2011 | 08:24 AM
mod06imprezasti's Avatar
Car Info: IMPREZA STI 2006
In the past few months I started to hear a noise coming from the front, it's like a grinding noise that comes from somewhere in the transmission area it sounds like. It only happens when I'm turning at low speed and it's not a constant grind it's sound like in steps, it doesn't happen when I'm turning at high speed or slowing down from high speed or accelerating in a straight line. It sounds almost as if the wheel was grinding against something while turning but I checked the wheel well and everything seems normal. Has anyone had similar problem? can anyone help out?
Red Bar0n
Jul 12, 2006 06:14 PM
Sinister Subaru
Apr 5, 2006 08:53 AM
GO24JUNIOR
Apr 1, 2004 07:45 PM
lost
Mar 20, 2004 01:06 AM
schiza
Jan 22, 2004 11:10 AM
